Old 03-08-2009, 06:02 PM   #1
natedawgg's Avatar
natedawgg is an unknown quantity at this point
could p1900 introduce noise in the system?
i have a p1900 that is running my mac mini. anytime i have the car turned on ( not even started yet ) i get this horrible humming noise through the system. the p1900 and mac mini are side by side in the glove box, but i can move the mini out and set it on my seat with no difference in the hum. could there be some sort of wiring problem that is letting the noise into the system?
Check out the new version of NAS, a cross platform music frontend here
natedawgg is offline   Reply With Quote
Old 03-08-2009, 06:32 PM   #2
PaulF's Avatar
PaulF is on a distinguished road
Try hooking up the mini to its normal power supply and hook it up to a standard wall outlet. If the noise persists, the problem is not the p1900.
My Car (Just the audio install as of now)
http://paulfurtado.com/car/
Worklog:
http://www.mp3car.com/vbulletin/work...-work-log.html
Planning 90%
Computer Build 88%
Programming 10%
Car Install 71%
PaulF is offline   Reply With Quote
Old 03-08-2009, 09:38 PM   #3
natedawgg's Avatar
yeah i have done that. the problem is that i have several different components in my setup, and i am just trying to narrow down the source. Essentially the setup is the p1900 powers the mac mini and the monitor, while i have a intermediate amp that pumps the signal to send to the car's factory amp (factory amp has to have a speaker level input in order to work). It seems though that it is the combination of all the components, because if i remove any one of them, as far as i can tell, the noise is not present. i tried hooking my iphone directly to my amp and there was no noise whatsoever. however, i need all the components in order to get the sound loud enough. i am just trying to determine if their is anyway that the p1900 could be the source.
Old 03-08-2009, 09:40 PM   #4
PaulF's Avatar
without the p1900 was there noise?
Worklog:
Planning 90%
Computer Build 88%
Programming 10%
Car Install 71%
Old 03-09-2009, 12:46 AM   #5
natedawgg's Avatar
no. when hooked up inside the house using factory power supply there is no noise.
also if i am in the car and plug in headphones instead of the plug to the amp, there is no noise. very weird.
Old 03-09-2009, 06:20 AM   #6
PaulF's Avatar
Keep the mini inside the car, but plug it into its indoor power supply.
It seems like the problem is going to end up being that there is an RCA cable run too close to a power line.
Worklog:
Planning 90%
Computer Build 88%
Programming 10%
Car Install 71%
Old 03-09-2009, 03:39 PM   #7
natedawgg's Avatar
good idea! I will try this out tonight and see how it works.
Old 03-09-2009, 05:26 PM   #8
itsasony is an unknown quantity at this point
macmini March 2009 voltage?
Does anyone have the power specs for the new March 2009 MacMini that uses less power?
itsasony is offline   Reply With Quote
Old 03-09-2009, 05:43 PM   #9
PaulF's Avatar
While you're at it, also check to see if this only happens while the engine is running or if it happens when the car is in accessory mode also.
Worklog:
Planning 90%
Computer Build 88%
Programming 10%
Car Install 71%
Old 03-09-2009, 07:15 PM   #10
PaulF's Avatar
That's a bit off topic. Next time, post in a new thread. A quick google turned up this page: http://forums.dealmac.com/read.php?4...820758,quote=1
I'm not sure how reliable that is though.
Worklog:
Planning 90%
Computer Build 88%
Programming 10%
Car Install 71%
Old 03-11-2009, 03:06 PM   #11
natedawgg's Avatar
Quote: Originally Posted by PaulF View Post
Keep the mini inside the car, but plug it into its indoor power supply. It seems like the problem is going to end up being that there is an RCA cable run too close to a power line.
so i tried this but my inverter is not strong enough to power the mini. im not entirely sure that it is an RCA cable because i have moved all of them the as far away from any power source as possible. I did do some re-wiring to make sure i wasn't getting any cross-talk in the wires. the funny thing is i noticed just last night is that if i turn my AC fan on high i get an extra high pitched buzzing sound. so i don't know what that means. it only happens when the fan is on full ( at 3/4 you don't hear it). my theory now is that there is some interference coming through the power system somehow into the mini that is then amplified later down the line before heading into the car's factory amp.
the noise is always there. even when you just turn the key to the accessory position, as soon as the mini boots up, you hear the noise. it is directly related to the mini. for instance if all the components are running except for the mini you will hear no noise, it is as soon as the internal components are running (hard drive, cpu, etc) that you get all of the static like noise.
Old 03-11-2009, 03:15 PM   #12
PaulF's Avatar
Nailed it. Inverters introduce noise into the system. What do you have running off of the inverter? Try taking the inverter out of the system entirely. I bet your problems will disappear.
Worklog:
Planning 90%
Computer Build 88%
Programming 10%
Car Install 71%
Old 03-11-2009, 06:01 PM   #13
natedawgg's Avatar
well, i was only using the inverter ( i may have made reference to the wrong thing here, i am trying to refer to a device that essentially gives me a standard plug in my car ) to test the mini in the car without requiring the p1900 for power. sorry for the confusion.
Old 03-11-2009, 07:52 PM   #14
PaulF's Avatar
That's exactly what the inverter is. They convert a car's 12 vold dc power into a standard home's 110 volt ac power.
So you were only using it for testing purposes?
Not what you want to use for a test. It will cause its own noise and not help us at all.
Just run an extension cord to your car from inside your house.
Worklog:
Planning 90%
Computer Build 88%
Programming 10%
Car Install 71%
Old 03-12-2009, 02:06 AM   #15
natedawgg's Avatar
i will see what i can do. i live in an apartment so it is not very easy to find an outdoor outlet near my car. i will see what i can find though. i must say though thank you for all of your help and suggestions on this. you have been very helpful.
Engine Noise due to ground loop or amp? matt11601 Car Audio 30 08-26-2009 09:38 PM
Car pc noise Not alternator noise. Please help jmkr53900 Car Audio 1 01-07-2009 10:23 PM
Thinking for a better system.. Help needed! l1nk General Hardware Discussion 15 05-09-2008 11:07 AM
Alternator Whine Only With Carputer tbird2340 Car Audio 25 06-29-2007 03:36 AM
New Russian GPS (Glosnass) available MobiTekLink GPS 5 04-05-2007 07:48 PM
