Quote: Originally Posted by
speakers_86
Starting the laptop shouldn't be a problem using webmaster's controller.
So I see 3 reasons that make the P1900 better than a DC/DC
No ground loops
Powers the screen
Regulated
Does that sound right?
The only reason that is valid is that the P1900 has the ability to power the screen with the extra 12v output.
The auto power adapter for your laptop will provide regulated power to the laptop.
Ground loop issues are a possibility with
ANY power supply, since it is usually a wiring problem.
The P1900 has a startup/shotdown controller built into the unit, so you wouldn't need WebMaster's controller. However, you'd need to crack the laptop open and wire something to the power switch. That may no be the easiest task in the world.
