Old 05-18-2009, 02:09 PM   #31
WuNgUn's Avatar
WuNgUn is on a distinguished road
I had no problem getting my PC to POST with the M4...
It just had no audio!!!
WuNgUn is offline   Reply With Quote
Old 05-18-2009, 06:57 PM   #32
Griff1's Avatar
Griff1 is on a distinguished road
Just powered mine up for the 1st time earlier today.
It went well i think but i was only using it in dumb mode.
Amp circuit seems to work,same as the M2 in that respect.
My pci sound card worked fine and there was no noise at all,i had noise with the M2.
More testing tomorrow as it all goes together.
P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,ROADRUNNER, iGo8, Custom Freedom 2.1
Griff1 is offline   Reply With Quote
Old 05-19-2009, 08:33 AM   #33
WuNgUn's Avatar
May the force be with you...
Old 07-01-2009, 07:27 AM   #34
seport is an unknown quantity at this point
I have just finished building my car pc. I am using M4-ATX power supply bought last month from cartft.com, so far i have tried the system at home using a power supply and a switch to simulate the ignition switch.
So far it is functioning very well, even the usb interface. I only tried tempering with the delay time to power on the PSU.
seport is offline   Reply With Quote
Old 07-02-2009, 09:13 AM   #35
High Voltage
blk02si's Avatar
blk02si will become famous soon enough
^ Looks like another successful build atop insulated standoff's.
blk02si is offline   Reply With Quote
Old 07-02-2009, 10:58 AM   #36
WuNgUn's Avatar
Nice and compact...I like!
Old 07-09-2009, 07:25 AM   #37
Crinos is an unknown quantity at this point
Realy nice buildt case there...
Crinos is offline   Reply With Quote
Old 07-11-2009, 10:43 PM   #38
shatteredzman is an unknown quantity at this point
I am going to go ahead and get the M4-ATX. I ran into a financial problem earlier and put my carpc on hold for a while and never bought a power supply. Then I got preoccupied with another project so I will try the M4-ATX and report back how it works out for me.
shatteredzman is offline   Reply With Quote
Old 07-12-2009, 03:06 AM   #39
Griff1's Avatar
My intelligent M4 was a retard!
The shutdown controller didn't know what it was doing, the switches had no impact on the shutdown time and it would crash quite often.
A friend of mine came round and flashed the 1.3 firmware to it and i havn't had a single problem with it since.
Griff.
Old 07-17-2009, 11:55 PM   #40
I got my M4 and it seems to work fine. I mounted it on insulated stand offs and I have it set to turn the computer on and off. I havnt fully tested the computer to make sure everything is working fine because it is getting late but I will get a picture of it and post it in the other major M4 thread soon.
*EDIT*
I have tested all of the M4 functions and everything works, not one single problem.
Old 09-07-2009, 09:55 PM   #41
summer69guy is an unknown quantity at this point
*EDIT*
have you tried it with a pci audi card?
summer69guy is offline   Reply With Quote
Old 09-07-2009, 10:47 PM   #42
No.
Old 09-08-2009, 11:47 AM   #43
bemenaker's Avatar
bemenaker is on a distinguished road
I have two of them, both of them from 2009, and mini-box added an extra plastic strip on the bottom of mine to insulate the two positive corners.
bemenaker is offline   Reply With Quote
Old 09-08-2009, 04:37 PM   #44
High Voltage
blk02si's Avatar
mine is still working great also. [Insulated standoffs]
Old 09-08-2009, 04:39 PM   #45
my m2 atx is making nosie into my sound card...(one of the jack is cliping....)when i try it with another psy there is no problem...so i would like to know if is there a way to hack the m2-atx(by changing some piece) to get it noise free
Testing Opus 150 via ATX - Computer is Continually Rebooting long.1 Power Supplies 13 07-19-2007 02:57 PM
morex 80wpsu and reg ATX cable dilema!! surfy Power Supplies 1 08-16-2005 09:06 PM
Micro ATX or ATX custardbomb Power Supplies 0 08-14-2005 07:48 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
