Quote: Originally Posted by
trader007
is this a common problem? where i turn on the ignition circuit, the power supply boots up and powers the pc fine, but after 5 sec the whole thing hard-shuts down, because the power j8 switch always stayed closed?
its like the power supply is holding down the switch button and wont let go.
if its not a common problem, im screwed arent i? because it really isnt going to work well this way at all...
Could be a few things. First I would check to make sure you have the polarity of the J8 switch correct. Every mobo is different, and it is not really a switch from the M2, so polarity does matter.
Next thing I would check is if that hardoff signal is actually the turn on signal. How soon after the ignition does it turn on? Unplug the J8 cable, and turn the car on (well get ign live). Does it still turn on? If so, it sounds like you have your BIOS settings to always turn on after a power failure. The M2 when it hardoffs is a power failure. When you turn the ign on, it gives power to the mobo but doesnt turn it on immediately. If your BIOS settings say turn on when it gets power then the mobo is what is turning it on. Then X seconds later, the M2 powers it on which would turn an already on mobo off. So check in the BIOS what the power button does. Is it set to immediately turn off, or press and hold?
