Old 03-11-2003, 07:31 PM   #1
Plexi PSU wiring...
ok, so i started on making my plexi case today. I am using a regular 250watt PSU (NOT dc-dc) and i wanted to shrink it down a bit and make it out of plexi also (never seen this done). I opened up the PSU and was looking at it when i noticed the ground wire attached to the PSU casing. If i use plexi i would have to attach the ground wire to the plexi, and it wont be grounded properly.
1.) How do you guys ground when using a plexi case, even if it is a regular PSU??
2.) What do you think of a plexi PSU??
Thanks.
2004 F-150
Shuttle XPC, 80gig HD, Wireless Internet, DVD
"How piMP3d is your ride??"
RaZor is offline   Reply With Quote
Old 03-11-2003, 07:34 PM   #2
Registered User
CrazyLittle's Avatar
If it's going in your car, just take that grounding wire and extend it out to where you ground everything else. If you're doing it for a PC in your home, extend that ground wire and attach it to the inside of your case.
CrazyLittle is offline   Reply With Quote
Old 03-11-2003, 07:39 PM   #3
ok, that sounds like it will work.
yep, its going in the car. I will just extend the cable and attach it to the car body i guess. It needs to be taken out easily too.
How about when i take the case inside and turn it on...what do i do then??
2004 F-150
Old 03-12-2003, 11:31 AM   #4
MP3DUB's Avatar
The ground wire is used to ground the case through the psu (case>psu>ac outlet gnd). I've got a wooden case at the moment, and dont have any problems between the components without the metal of the case to ground them together. And there's a company out there that makes the U shaped piece of the psu cover out of plexi for those people that want their psu to be "unique." Otherwise, you should be fine. Theres even a tutorial out there somewhere on how to fit a standard atx psu into a cdrom drive.
-Nick
_____________________________
Monthly MP3Car Chicago Meets
www.mp3vw.com Last updated: 07/07/2008
MP3DUB is offline   Reply With Quote
Old 03-21-2003, 06:18 PM   #5
Registered User
so if you use a plex case setup do you need to ground the cards in the motherboard ?
FEEL THE RUSH
P4 1.7, 1gb sdram, 40gb 7200, ati dual video, 5.6" In dash, 13" lcd touch screen in back.
96 gt conv. Mustang
V_C_F_666 is offline   Reply With Quote
