Old 07-01-2009, 02:45 AM   #1
noobified is an unknown quantity at this point
Does the ignition wire from a radio harness actually provide power?
Can I tap a small screen's 12V power to the ignition wire in my radio harness so that it will turn on when my ignition is on?
noobified is offline   Reply With Quote
Old 07-01-2009, 04:24 AM   #2
colin's Avatar
colin will become famous soon enoughcolin will become famous soon enough
It supplies power, but not much at all.
The answer is no, you can not.
2001 Mustang Convertible Worklog
Indigo Custom Frontend (Flash/Delphi)
Blog
Code:
Currently: - Working on my new product! Wiring: |■■■■■■■■■■■■■■■■■■--| Trunk: |■■■-----------------| Sound: |■■■■■■--------------| Screen: |■■■■■■--------------|
colin is offline   Reply With Quote
Old 07-01-2009, 05:52 AM   #3
Crinos is an unknown quantity at this point
You can use this 12V to control a relay.
Crinos is offline   Reply With Quote
Old 07-01-2009, 06:11 AM   #4
bad_luck's Avatar
bad_luck is an unknown quantity at this point
it will sure work like crinos said, but in my car i just attached the screen to this wire, works perfectly. A screen doesn't use much power, so probably won't be trouble. A friend of mine did it the same way, but that's the same car (same brand, same type). Maybe other cars will have trouble with it !
bad_luck is offline   Reply With Quote
Old 07-01-2009, 06:20 AM   #5
As you said... Some cars can handle it with out a problem, others can't power jacks a... from the ignition wire.
On my BMW the ignition cable is "low powered", but there are several "free" 12V cables that light up when ignition is ON.
Old 07-01-2009, 06:30 AM   #6
bad_luck's Avatar
true, my civic has the same, now that you mention it.
2003 Honda Accord Sports Coupe - a worklog nasa Worklogs 21 10-03-2008 07:15 AM
ignition wire TeamRSX Car Audio 8 05-16-2008 10:53 AM
Bloomin' alternator whine Vodkapete Car Audio 4 05-03-2007 06:25 PM
Opus ignores ignition wire, constantly stays on Sham-Mobile Power Supplies 1 08-26-2006 07:28 PM
Do I Need To Beef Up My Alternator Or Anything Else chitown_16 Car Audio 23 06-19-2006 07:39 AM
