Old 07-03-2009, 02:41 PM   #1
mchaimech is an unknown quantity at this point
Bluescreen on ignition.
Hello all,
I recently installed a carpc in my BMW 2001 X5, and here are the specs:
Intel MB DG41TY
2.8 Core2Duo processor
2GB RAM
500GB 7200 RPM HDD
Powered by an M2-ATX power supply with the following jumper settings:
A B C D
Off On On Off
Off-delay= 30min
Hard-off= Never
OS: Microsoft Windows Vista Ultimate.
Connected to a Prology PCM-750T motorized screen.
Well, I have two problems:
1- When I turn off the car, the PC stays on, as it should be (but the screen gets off -normal-), but when I start the ignition again, I get a bluescreen and then computer restarts.
1- When the car is started, everything works just fine, but sometimes the computer hangs after the Windows boot screen, So the welcome screen doesn't get displayed, until I reset the computer, and sometimes after many resets.
Any help concerning one of the two problems is more than appreciated.
Thank you in advance.
Best regards;
MM
mchaimech is offline   Reply With Quote
Old 07-08-2009, 04:47 PM   #2
Thank you for your help...
Problems solved.
ignition wire TeamRSX Car Audio 8 05-16-2008 10:53 AM
M2-ATX Ignition Current Pull? incudie Power Supplies 8 09-18-2007 09:44 PM
Ignition Switch Details? brianafischer General Hardware Discussion 5 09-23-2006 10:31 AM
In search of an ignition wire witten Power Supplies 16 07-27-2006 02:29 AM
Ignition and Button on/off power TurboTronix Power Supplies 4 04-25-2005 01:02 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
