Old 07-14-2009, 03:11 AM   #1
TheGuv is on a distinguished road
Do I need a fused distro box?
I've got a JBL GT5-604A sub which has it's own blade fuses and my M2-ATX-HV PSU which has a 15a blade fuse.... Question is, with them both being fused already, do I need to use a fused distro box or can I just use a cheap unfused one?
Thanks in advance!
TheGuv is offline   Reply With Quote
Old 07-14-2009, 07:27 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
A fused distro block is more convenient.
You can use one without fuses, but you still want to fuse the lines after the distro block because of the wire gauge change.
The fuses on the power lines are to protect the wiring, not the components they are powering.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 07-14-2009, 07:46 AM   #3
So might be pointless having fuses on 1m lengths of 8AWG cabling? It's got a 60a fuse from the engine bay, 4AWG wire running along the car then needs to be split into 2 8AWG cables for the amp and the carpc which are side by side, so two 1m 8AWG cables will be plenty, to be honest I'd probs only use 0.5m cables as the distro box is next to both inputs of the components...
Old 07-14-2009, 07:52 AM   #4
ThePistonDoctor is an unknown quantity at this point
Fuse them. A fuse is ~$1. Your cost will be much more if the wire welds itself to your frame. I've seen it many times. Just fuse it.
ThePistonDoctor is offline   Reply With Quote
Old 07-14-2009, 08:37 AM   #5
Crinos is an unknown quantity at this point
I have a 100A fuse close to the battery, then I have the distro box further down the line with even more fuses.
I want a fuse close to the battery so that incase of something happening, the chances for a car fire is less present.
Crinos is offline   Reply With Quote
Old 07-14-2009, 08:53 AM   #6
Yep a fuse in the enginebay is a must, without a doubt... I'll get a fused distro box, shame though as i had a non-fused one with a LCD readout for amps & volts which matched perfectly with my other readouts in the boot!
Old 07-14-2009, 10:02 AM   #7
nalav's Avatar
nalav is on a distinguished road
The fuses on the amps are to protect the amps. The fuses on the cables are to protect the cables. You need them, it's a potential electrical and fire hazard without them.
nalav is offline   Reply With Quote
Old 07-14-2009, 11:10 AM   #8
No need to lose a distro block you already own.
Just get fuse holders and put them in place after the outputs of the distro block.
As I said... A fused distro block just makes it more convenient. It is not a necessity.
Old 07-14-2009, 04:03 PM   #9
Good point. Personally I'd just sell the unfused and buy a fused one so I didn't have to do as much work cutting up the wires lol
Building Custom Box in Enclosed Space? Dr.jinG Fabrication 9 01-28-2007 02:33 PM
EPIA-M custon box xpluis Fabrication 5 12-03-2006 05:56 PM
Noob question (capacitor and sub box) greatkiller Car Audio 16 11-13-2006 12:22 AM
RSX Car computer in glove box Zerach Fabrication 6 07-18-2005 07:28 PM
Wanting help with an ABC sub box FyreDaug Car Audio 4 07-15-2005 05:10 AM
