Old 07-20-2009, 02:15 AM   #1
TheDrake is an unknown quantity at this point
Best option for netbook, p1900 or ACPPSv1?
I have been looking at both of these products for use with a Dell mini 10 netbook as a carputer, but they both seem to be pretty overkill for the kind of power I am needing but seem to be the only options that I can see right now.
The P1900 actually has a pulse turn on which is nice and the ability to power my laptop, screen, and a usb hub with the add on. But there may be times when I dont want the unit on at all for driving down the street or moving the car out of the driveway to let someone out, etc... I guess I could put a switch on the ignition wire to solve that.
The ACPPSv1 is great cause it wont turn on unless the netbook is on which will require a switch to turn on everytime I start the car which isnt a huge deal to me, but its still an inconveience. It has the 5v output for a usb hub, and unregulated 12v for the screen, but I would need to buy an adapter for the netbook itself which would cost an additional $66 from lind. The 12v would work for the amp turn on as well.
Are there any other better alternatives to either of these? If not, for what I plan to use it for (netbook, monitor[not a huge issue since I can hook it up straight to battery], usb hub, and amps) which one would be the best option? any help and advice is appreciated!
TheDrake is offline   Reply With Quote
Old 08-02-2009, 10:57 PM   #2
DarkStar02's Avatar
DarkStar02 is an unknown quantity at this point
Now that you can get a refurb mini 9 for under 200 I'm really interested in buying one of these to use as a car PC. Mount a touch screen in the dash and throw the mini in your glovebox, use the wake on lan feature and the minispark (not yet available, soon to be $99) and you basically have a carPC. Not sure how the laptop would be powered though, probably through an inverter so you don't have to cut up the power brick.
Silver 2001 Ford Ranger XLT
[ ██ 10% ░░░░░░░ ]
http://www.mp3car.com/vbulletin/show-off-your-project/96582-2001-ranger-xlt-worklog.html
DarkStar02 is offline   Reply With Quote
Old 08-03-2009, 12:42 AM   #3
I ended up getting the P1900 with the addon 5V. The netbooks usb ports dont provide enough power for DAC's I have so I had to go with a powered USB HUB. Its the best and most cost efficient route that I found.
Opinions Please PicoPSU P1900 Urbanmindz Power Supplies 11 05-22-2009 10:33 AM
Instant Boot-up Media Player OPTION kickercivic1 General Hardware Discussion 6 06-23-2007 09:07 PM
Lilliput woes timekiller Linux 8 06-19-2007 11:22 PM
Commell LV-670M No Option to Standby 2k1Toaster General Hardware Discussion 5 03-30-2007 01:02 PM
Carnetix P1900 jorgenjl Newbie 5 06-22-2006 01:08 PM
