Old 08-05-2009, 05:06 PM   #1
Punky is on a distinguished road
DSATX Bricked, anyone else has similar experience?
It seems that the current generation of DSATX on mp3car has some sort of problem. Instead of just sending it back for repair, I'd like to get to the bottom of it. I know I didn't do anything wrong because I did everything the exact same way I do with my older DSATX (minutes before), and everything is worked flawlessly. Here is the problem: The DSATX works flawlessly out of the box, but the moment i attempt to do any sort of modifications using the brainstem the DSATX would completely die. No output on any rails, no lights, nothing. When i attempt to firmware upgrade the system responses to the restart and begins updating, but never finishes. This is my second one from mp3car. I have contacted jeff, and I'm awaiting his response.
Punky is offline   Reply With Quote
Old 08-06-2009, 09:14 AM   #2
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
i havent seen any other posts indicating there's an overall issue with the product so i dont think there's an issue with the mp3car batch of DSATX (hope not i'm ordering one today). Jeff's support of his hardware is top notch so i'm sure he'll get to the bottom of it for you.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 08-06-2009, 12:14 PM   #3
The thing is, most people do not need to change any parameters with the DSATX, because it works great out of the box. Hence if there was a problem, its probably not that obvious. I do hope its an isolated issue. Really, for my new DSATX the only parameter i need to change is the lowtemp, because it gets below -40*C here, so if i don't change the parameter I won't be able to use the carpc for most of winter.
Old 08-06-2009, 02:06 PM   #4
RipplingHurst's Avatar
RipplingHurst will become famous soon enough
I bricked one, but it was out of the one year warranty, so I bought another one for sale. Wish I could fix the first one though, so I could use on another car.
Never knew what was the cause, but I could update the firmware once (from 1.13 to 1.14 I think), no issues. I changed low volt and some timing issues, it worked for a while and then it simply stopped working, it was not dead, i tested every connector, 5v rail, was working fine, but no 12v output whatsover.
Worklog - 07 Infiniti Fx35 Carputer
Worklog – 06 Infiniti M35 Carputer (sold!)
RipplingHurst is offline   Reply With Quote
Old 08-06-2009, 02:19 PM   #5
mine doesn't even feed the brainstem with any information. so i have no idea how to diagnose it.
Old 08-06-2009, 02:22 PM   #6
Oh, I did that with a multimeter, the brainstem would report just garbage.
DSATX 5 blinks jbradshw Power Supplies 3 07-18-2009 09:40 PM
M4-ATX or DSATX ibm_jennifer Power Supplies 20 04-22-2009 11:36 AM
Brand new DSATX won't start up... zerodb Power Supplies 11 09-10-2006 01:55 AM
Fabrication Source Websites (LED, Plastic, Plexiglass, Fiberglass) nFiniteTuning Fabrication 21 05-03-2006 12:28 PM
has anyone made something similar to the Empeg RIO player vash General Hardware Discussion 0 09-02-2002 04:23 AM
