Old 08-08-2009, 12:52 AM   #1
hutacars is an unknown quantity at this point
Calculating RMS wattage
I have a power supply that draws up to 185 watts. I also have an amp ordered which can output 100 watts per channel, and it has 4 channels. What is the RMS wattage of this setup? Is it 585 watts, or are the amp outputs of a "different" sort of wattage? I don't really know how to phrase this any better... but what I'm asking effectively is is it the same terminology but with a different meaning between amp watts and RMS watts?
hutacars is offline   Reply With Quote
Old 08-10-2009, 10:27 AM   #2
soundman98's Avatar
soundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the rough
car amps are all over the place on ratings, so there would not be any way for anyone to give you a accurate measurement of it, unless the amp was cea certified-- all of it would be guesses. most amp outputs are rated with 14.4 volts, cheap brands have rated amps with as high as 24 volts, which would normally void the warranty, but they use this to make it appear that it is a better deal than it really is (24 volt input would make the amp seem 2x's more powerful on paper-but would never work in real life for more than a couple minutes).
becasue so many companies have skewed the term of what a watt really is(though, if you are using a cea certified amp, it will truly be putting out what the specs say), the easiest way to determeine the max load would be to add up the fuses.
soundman98 is offline   Reply With Quote
Old 08-10-2009, 01:58 PM   #3
wpiman is an unknown quantity at this point
Edit; sorry misread the question.
wpiman is offline   Reply With Quote
Old 08-10-2009, 04:10 PM   #4
Thanks. I'll try adding up the fuse ratings once my amp arrives (should be any day now...).
1000w Rms Amp On 2000w Rms Sub OriginalRudeBoy Car Audio 10 03-05-2008 03:42 PM
Calculating Inverter Wattage Needed brucedog Power Supplies 5 01-13-2008 09:18 PM
Best way to determine wattage? maxxell General Hardware Discussion 4 04-21-2005 06:38 PM
wattage of processors - sempron/intel cel "D" fuctup General Hardware Discussion 23 12-23-2004 11:31 PM
AC Wattage vs. DC Wattage SwapMeet Power Supplies 4 11-09-2004 01:03 AM
