Old 09-12-2009, 09:09 PM   #1
nitefallz is an unknown quantity at this point
PC Turns on then off after standby
Weird problem here:
I'll turn the car on, and everything starts up fine. Turn the car off, system goes into standby. Turn it on again (tried a few seconds after to 15 minutes later) and the PC fires up, then shuts off. If I turn on again the PC does a cold boot and stays on. It's like the power gets cut waking up from standby, but why?
D945GCLF2D (Atom 330)
2gb ram
Liliput EBY701
Using an Opus DC-DC 90w
nitefallz is offline   Reply With Quote
Old 09-12-2009, 10:38 PM   #2
Super Moderator & Wal-Mart Greeter
Tidder's Avatar
Tidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant future
Are you sure the PC is powering down? Or is the screen just blanking...
Tidder
Try RevFE
The best frontend I've ever used, period.
Best Quote EVER!!
Quote: Originally Posted by bramlet View Post
I try to search but I usually only find posts where people ask questions and darquepervert tells them to search.
Tidder is offline   Reply With Quote
Old 09-12-2009, 10:45 PM   #3
Tidder's Avatar
Also, have you tried with a standard desktop PSU? Maybe it's the Opus.
Tidder
Try RevFE
Best Quote EVER!!
Old 09-12-2009, 11:54 PM   #4
Everything is shutting off, both times. I had the Opus running off a standard PSU inside and once the standby didn't work at all, it went into standby mode, but didn't stay there. After that, everything worked properly. I wonder if the battery is an issue.
Old 09-13-2009, 12:15 AM   #5
Hmm, a BIOS update may be needed.
Old 09-13-2009, 02:04 PM   #6
Tidder's Avatar
Interesting. I've used quite a lot of D945GCLF2(D) mobos without issue, but with M2-ATX PSUs. Where did you find info on the BIOS update, and is it a specific Opus problem? Or just a problem in general...
Tidder
Try RevFE
Best Quote EVER!!
Old 09-13-2009, 11:31 PM   #7
I was going through the list of fixes in the previous updates and one of them said something along the lines of S3 stability being fixed. I applied the update and it seems to be working so far, but I'm not 100% sure just yet because I ran into another problem with a frayed wire powering the HDD which was crapping out on me. I fixed that but didn't have time to test it so we'll see what tomorrow brings.
Old 09-14-2009, 12:24 AM   #8
Tidder's Avatar
Awesome! I had no idea about the S3 stability. I'll keep that in mind on new builds.
Tidder
Try RevFE
Best Quote EVER!!
Old 09-14-2009, 02:20 PM   #9
Standby seemed to work the way it was supposed to. I have it set to go into hibernation after an hour, and the car woke up from hibernation this morning meaning the standby didn't crap out. But it looked like RR crashed as I was greeted with a blank desktop and no mouse, but the keyboard was responsive (kind if like if you force close RR). Not sure if there's some connection here or if I'm having some unrelated power issues.
It's a pain to test everything in the car. I should get a spare battery and test everything in the house.
Old 09-16-2009, 09:20 PM   #10
It was working for a few days, now it's crapping out. After going into standby all power to the board is being cut. I'm pretty clueless at this point.
Old 09-16-2009, 10:30 PM   #11
Tidder's Avatar
I have zero experience with the Opus, but when the car power is cut, does it send a signal to the PC to have it shutdown/standby, then wait for a pre-set amount of time before hard cutting power? That's all I can think of other than faulty hardware somewhere else.
Tidder
Try RevFE
Best Quote EVER!!
Old 09-17-2009, 09:05 AM   #12
Ten seconds after the ignition signal is gone it will send a "power butten press" to the computer which is set to enter standby. After 1 hour it will go into hibernate. The Opus board should only cut the power completely from the system if the battery voltage drops under a certain level. So either my battery is suddenly low on charge immediately after I turn the car off, or something else is flakey.
Old 09-17-2009, 10:18 AM   #13
I managed to find the manual for my PSU online and it says that the standby power is turned off immediately following shutdown if the jumper is not set. I have the jumper on the pins though. It came off, and I placed it back on but I guess it might be loose? I should just solder the two pins together. Unfortunately I have 8 more hours of work ahead of me before I can take a look!
Old 09-17-2009, 09:32 PM   #14
I soldered the two jumper pins together, seems to be working now!
Old 09-17-2009, 10:06 PM   #15
Tidder's Avatar
Sweet! These PSU manufacturers should use switches instead of jumpers...
Tidder
Try RevFE
Best Quote EVER!!
