Old 09-13-2009, 02:55 AM   #1
beerbucket is an unknown quantity at this point
Help with Opus SFX-1215 hookup
Hi All,
Just getting started on my first carputer project, and have acquired the above Opus power supply from a friend.
I looked up the datasheet:
http://www.opussolutions.com/pdfs/DC...-15-MAR-04.pdf
On page 3 it says to connect the input connector pin 3 to "ignition or power switch".
My question is this: is it looking for a momentary pull-up to 12v on this line, or does this line need to be *held* up at 12v to keep the PC running? Another way of asking this might be: do I connect to the START or the RUN position on the key barrel?
I think it probably needs to be held up at 12v to keep running, then it sends the shutdown signal after the 12v disappears, but I thought I should check. :-)
Thanks in advance!
beerbucket is offline   Reply With Quote
Old 09-13-2009, 09:02 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Your thinking is 100% spot on. It needs to be held at ~12v for the PSU to remain on.
When the voltage drops to 0v, the PSU sends the pulse to the motherboard to trigger shut down. It essentially simulates a press of the power button, which Windows interprets and handles accordingly.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Intel GLY2A and Opus 150 Watt Issue PDiddy Power Supplies 5 04-07-2008 05:21 PM
Opus and BMW (e46) captain_jim1 Power Supplies 24 01-21-2005 12:46 AM
86% Efficient AC-DC ATX supply auto_robotics Power Supplies 42 11-25-2004 03:16 AM
Hot Hot OPUS!! god_of_cpu Power Supplies 11 06-22-2004 06:02 PM
Troubleshooting 150W Opus (turns off after 20-30 mins) [iG] Power Supplies 8 06-05-2004 11:13 AM
