Old 09-17-2009, 03:02 AM   #1
hexxamillion's Avatar
hexxamillion is on a distinguished road
Does Zotac IONATX A-U still need a regulator
I am going to purchase the Zotac ION A-U which has an onboard PSU. I was wondering if anyone has done an install with this unit and if connecting it to the P2140 would be redundant or unecessary.
"Live Free!!!...It's all about Open Source"
Worklog: '05 Nissan Altima Project (Intel D945GCLF2D)
Project #2:Solar Power Integration
Vimeo Vids:Project Videos
Blog: Hexxamillion.com- 100% Powered by Wind Energy
Twitter:http://twitter.com/hexxamillion
hexxamillion is offline   Reply With Quote
Old 09-17-2009, 03:07 AM   #2
sergatiuk's Avatar
sergatiuk has a little shameless behaviour in the past
i dont know about the regulator, but if you get the board get it from newegg.com or tigerdirect.com
save some $$$ for beer
im pretty sure though u need one ... i would go with B-E board and get one of those m2-atx (i think thats what its called) power supplies
sergatiuk is offline   Reply With Quote
Old 09-17-2009, 03:44 AM   #3
nisarg86 is an unknown quantity at this point
Why are you going for on board PSU model ? Get the B-E model. which has 20 PIN connector.
I am using D-E model. and it works like a charm with 160W DC-DC PSU.
nisarg86 is offline   Reply With Quote
Old 09-17-2009, 03:55 AM   #4
HuseyinOzsut is an unknown quantity at this point
I think onboard psu can not operate in car. I don't think it can ragulate the car 12V.
Also in time you can need more powerfull psu or onboard psu can break down. Tou won't be able to use another psu if mainboard doesn't have any pins. Also m2-atx is around 70 dollars. Intel atom mainboard is also around 75 dollars. Combination of the two is cheaper and safer I guess...
HuseyinOzsut is offline   Reply With Quote
Old 09-17-2009, 06:32 AM   #5
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
The board requires 19vDC.
You need a power supply that can output 19vDC. An M2 can not do this, as it outputs the 3 voltages ATX compliance requires (12v, 5v, 3.3v).
A Carnetix P1900 or P2140 is the ticket here.
Do you need to regulate the power from the car going into the Carnetix? No.
nisarg86 is correct. The B-E variant has the 20-pin ATX connector, which will work with an M2 or any other ATX-compliant PSU.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 09-17-2009, 11:35 AM   #6
Thanks for the feedback. I will keep all of this in mind.
Old 10-06-2009, 09:16 AM   #7
AndyWhittaker is an unknown quantity at this point
Thumbs up
I am constructing a Car PC at the moment and have the same board.
I have used a universal 12V Laptop PSU. Comes with all the bits you need and you just set its output to 19VDC.
Good Luck!
Andy
AndyWhittaker is offline   Reply With Quote
Old 10-09-2009, 12:22 PM   #8
david69leonard's Avatar
david69leonard is an unknown quantity at this point
I am running the D-E version with a M4 atx and this motherboard is sweet!!! To say the least. I thought about purchasing the one with the built in pwr supply but it seems like too much of a hassle, glad i didnt. The problem i see is the fact you dont have start up shut down control. It would be perfect for home entertainment use but not very practical for automotive. So i would suggest the D-E version, pls it comes with built in Wireless N.
david69leonard is offline   Reply With Quote
Old 10-09-2009, 07:29 PM   #9
Good Luck!
Andy
Laptop PSU? So what do you do about start/shutdown control and anti-thump?
Old 10-09-2009, 07:31 PM   #10
I purchased the Intel D945GCLF2D Mini-ITX instead, but regarding the M4 ATX, I have been considering that one. So how has it been working for you?
Simple 12v regulator question aalouie Power Supplies 3 01-14-2009 10:23 AM
PW-200 V and Regulator Question VehicrossPC Power Supplies 5 02-02-2006 12:16 PM
Voltage Regulator Constant Heat phita23 General Hardware Discussion 17 02-21-2005 01:18 AM
FS: Morex Car Power Regulator Kit (Brand New) migel628 Classified Archive 4 04-07-2004 12:26 AM
Idea for a cheap 12 voltage regulator perhaps... adamis General Hardware Discussion 5 09-11-2003 08:31 PM
