Hello guys Here we go again.
I have the Intel D945GCLF2 mother board.
I just bought my M2-ATX and i have checked the Wiring 5 times, and my best mate who has the same PSU with no issues on his end.
I have the PSU running currently in
Mode 2
I Turn my Switch
ON and the computer boots into Windows Vista SP1 Perfect and very fast.
I press my switch off and the computer shuts down and turns off for 3-5seconds and boots back into windows.
OR
I press
Start > shutdown > OK and the computer shuts down and turns off for 3-5seconds and boots back into windows.
The
Remote wire has 0.00Volts running to it when the switch is
"OFF"
when the switch is on it has
12.46v
I made a short and separate Remote switch because i though that might have been my issue but even after making another short one in my boot i am still getting the same problem.
I am going to go home after work and check everything
ONE LAST TIME and touch base on this I am more than sure everything is fine and i have everything correct.
The P4 power supply that goes from the PSU to the Mobo i had to make my self as i couldn't buy one.
I just copied both of them to each other. so i think that is correct...
thePost i made earlier with this problem i thought might have been the issue I formatted and reinstalled windows as it was on my 24V PSU before i got M2-ATX but that wasn't the case my issue is still happening.
This here is also another Post i made referring to this issue ::
HERE
