Old 09-20-2009, 12:50 PM   #1
VXCompyBox is an unknown quantity at this point
Problems with my power supply
Hey guys,
I think I'm running an M3 ATX. This unit has worked perfectly in the past, but since re installing, it will only power intermitantly. I've measured the voltages at the power in and acc trigger wires, both being at about 11 - 12 volt. And both are wired correctly. The only thing that has changed is I'm now earthing to the chassis as oppose to running a negative lead from the battery.
I was thinking that perhaps the unit is going into the battery saver mode or whatever it is, where when the voltage drops too low it shuts off the 5 volt rail. But this doesn't really make a lot of sense as it's not operating consistently at all.
Or the other option... has my power supply died?
TLDR; When turning the key, power supply won't turn on, connections correct.
VXCompyBox is offline   Reply With Quote
Old 09-20-2009, 01:29 PM   #2
JuniorGeezer is an unknown quantity at this point
Can you temporarily ground the power supply from the battery again and see what happens?
JuniorGeezer is offline   Reply With Quote
Old 09-22-2009, 09:35 AM   #3
Update:
Since my last post, I've run a set of jumper leads to the end of the car (where the pc is) and measured the voltage, which turned out to be near on identical, also connected the jumpers to the PSU and same result. Any other ideas? I may have to post some pics, on my Mobo the PSU doesn't sit perfectly in the ATX plug, theres a capacitor in the way, But as I've mentioned, it hasn't been a problem in the past, i don't understand why it would start now,
Old 10-10-2009, 01:25 AM   #4
Gerard48 is an unknown quantity at this point
the M3 won't turn on if the voltage is less than 12, could that be the problem? not enough power?
I see that you mentioned the power reading is between 11-12, try and use another battery somehow and see if it is still happening
Gerard48 is offline   Reply With Quote
Old 10-10-2009, 06:29 AM   #5
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
What do you mean that you THINK you're using an M3? That statement means you are maknig an assumption, and we all know what happens when you assume, right?
It sounds like you are using an older PicoPSU which has a similar formfactor as an M3, but requires regulated 12v.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
USB Syncroized 5V@8A power supply POL. Now Taking Orders!!! Beehphy User Innovations 110 06-23-2009 04:22 PM
power supply confusion CapnBoost Power Supplies 3 04-26-2007 08:59 AM
FAQ: Will <insert PSU model> Power Supply work with my system? DarquePervert The FAQ Emporium 9 10-10-2006 01:38 PM
power inverter power supply shutdown problem launter Power Supplies 10 09-21-2005 12:12 PM
Power Supply Options? Optikal Power Supplies 9 06-26-2004 06:46 AM
