Old 09-26-2009, 05:04 PM   #1
Maheriano will become famous soon enoughMaheriano will become famous soon enough
How To: Power 2 Amplifiers With A M2-ATX
I have a Rockford Fosgate Punch P300.1 amplifier for my subwoofer and it requires a higher power input on the remote line than the M2-ATX can provide so here's how you can solve this if you're having similar issues.
Tools you will need (maybe):
A computer to read this DIY
Soldering iron
NPN Type Switching Transistors
Wire stripper
solder
lighter
heat shrink tubing
random lengths of wire
refreshments
What To Do:
Take out one of the transistors and bend the pins out so they're easier to work with:
Connect some lengths of wire in a Y shape to branch off and connect to both amplifiers:
Solder the wires together:
Cut off a piece of heat shrink:
Solder it to the transistor along with a power wire. The placement of the wires is detailed on the back of the packaging for the transistors:
Heat up the heat shrink so it shrinks around the wiring and seals it up:
solder on the final wire in the car:
Now when you turn on the computer it should power both amplifiers as well. Enjoy!
Ampie Case
256 MB DDR2 PC5400
Xenarc 700TSV - VGA Monitor
Intel D945GCLF Motherboard
M2-ATX-HV
2005 Honda Civic
Maheriano is offline   Reply With Quote
Old 09-26-2009, 05:34 PM   #2
barnyard is an unknown quantity at this point
Nice how-to, but you really should include some detail as to what goes where!
D201GLY2
512 Megs RAM
8" Lilliput
Onstar GPS mod
XM
Visteon HDZ300
barnyard is offline   Reply With Quote
Old 09-27-2009, 12:44 AM   #3
There are 3 pins coming off the transistor, they go to the battery, 1 to the amplifiers and 1 to the J6 connector on the M2-ATX. The diagram on the back of the transistor packaging will actually show you which wire is for what, I won't post it here because it might differ between transistors. It's really rather simple, there's not much to say.
EDIT - I'll explain it briefly here.
The pins are numbered and the numbered diagram is on the back of the packaging. But one pin is labeled as COLLECTOR and that will take the input from the power supply. In my case it's the J6 connector on the M2-ATX. Another pin is labeled BASE, this is power from the battery of the car. The last pin is labeled EMITTER, this sends the power out to the amplifiers, split the wire and run it to each amplifier. Done.
Ampie Case
256 MB DDR2 PC5400
M2-ATX-HV
2005 Honda Civic
FAQ: How do I power my DC-DC PSU on my workbench? DarquePervert The FAQ Emporium 54 08-04-2009 10:11 PM
WTB M1, M2, or M3 ATX power supply akumar5 Classifieds 1 11-06-2008 11:41 PM
miniITX power supply for ATX motherboard? uldics Power Supplies 4 09-26-2007 01:17 PM
M2 ATX power supply wiring question... 3 terminals Snortonnorton Power Supplies 5 07-25-2007 08:25 PM
Pundit atx power connector essamch007 Power Supplies 4 08-17-2006 01:04 AM
