Old 10-09-2009, 10:16 AM   #1
MGSteve is an unknown quantity at this point
Asus AT3N7A-I PSU Help
Hi Guys,
I'm about to build my first CarPC and I'm a bit confused about which PSU I need for it.
It shouldn't be too power hungry, its just the Mobo and a SSD that it needs to power. But it needs a 4pin 12v supply for the CPU in addition to the ATX supply, none of the PSUs I've seen have this second output.
I think I'd go for the 60w CarNetix PSU, but stuck about the wiring.
That said, I have got an 80w PicoPSU that I bought for an earlier attempt, but it doesn't have the SATA connection I need. (Although could use an adapter) - but still doesn't have the secondary 12v input.
Any help would be appreciated
MGSteve is offline   Reply With Quote
Old 10-09-2009, 10:39 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
First off, start peusing the FAQs: http://www.mp3car.com/vbulletin/advfaq.php
That board is an ATX-compliant board, so you really need an ATX PSU.
M-series, Opus or DSATX are your options. It all depends on the features you want, your budget and how much space you have available.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 10-09-2009, 10:43 AM   #3
North of the land of Hey Huns
malcom2073's Avatar
malcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to all
perusing* :P
But seriously, what he said. I personally have a m2, and it's worked great for me. Definitely get yourself a PSU with a shutdown controller built in.
RevFE - Try it, you just might like it.
Carbon - Next Generation Touchscreen Browser
Come join us on IRC: irc.efnet.net #mp3car
Audiophiles make me chuckle as they pad my wallet.
malcom2073 is offline   Reply With Quote
Old 10-09-2009, 11:38 AM   #4
The m2 still doesn't have the 4 Pin CPU power connector though?
4 Pin, top right between the caps.
Ah, I notice the DSATX has, that's spot on. - Although I don't need 220w! Don't they do a lower power one?
The FAQ doesn't mention the 4 pin CPU power connectors at all btw...
Update - do'h, just noticed the M2 does have the 12v CPU connector as well. Cheers for the help
I presume with a M2, you don't need a power regulator like a P1290 then? You just wire the M2 into the car?
Old 10-09-2009, 04:43 PM   #5
soundman98's Avatar
soundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the rough
you could use something like this for the 4 pin connector: http://store.mp3car.com/4_Pin_P4_Mol..._p/cbl-056.htm
all atx compliant dc-dc power supplies just need to be connected to the battery-- they will regulate the voltage to the motherboard.
soundman98 is offline   Reply With Quote
FS: Asus A7N8X-VM/400 nForce2 mobo with amd 2000+ and other various items. Kalt Classified Archive 6 04-21-2006 03:35 PM
Frequently Asked Questions bgoodman The FAQ Emporium 33 05-03-2005 07:25 PM
Lots of PC components, Asus Motherboard A7N8X, Antec True 480 PSU, Etc schapman43 Classified Archive 4 12-28-2004 08:45 PM
Mastero 3.5 12v-12v PSU KIT fs SteveC Classified Archive 0 09-28-2004 12:04 PM
Powering up normal ATX PSU KimaX Power Supplies 5 09-28-2004 01:08 AM
