Old 10-21-2009, 11:07 AM   #1
Larzfromarz is an unknown quantity at this point
Use a Pico 90 for display PS?
Hi Guys,
I recently purchased my first components for my Truckputer-
The CPU is a MCS-BB-350 from MO-CO-SO.It comes with a Pico 90W PS that I expect is a bit underpowered for what I'll be hanging on it, so I purchased a M4-ATX PS. It won't fit in the case (no problem) but I am removing the PICO as you would expect.
Can I repurpose this baby PS to use as a regulated supply for my 10" touch screen?
Any thoughts or comments?
Larz
Larzfromarz is offline   Reply With Quote
Old 10-21-2009, 01:15 PM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
If the screen requires 12vDC (Unlikely that the TS would require 5vDC or 3.3vDC), then you can, but it would be a kluugey setup.
Assuming the TS requires 12vDC, then I think it would be easier and more reliable to power the TS from the M4 instead.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 10-21-2009, 02:09 PM   #3
Darque-
I take no offense, but why would it be kludgy? I'd think an independent regulated PS might be more useful in that it sharing the total system load would save the M4 from peaking (remember I am loading it up- though not the 12v rail too much).
Its just a thought cause PICO is extra at this point.
Keep em coming-
Larz
Old 10-21-2009, 03:11 PM   #4
nobb will become famous soon enoughnobb will become famous soon enough
Most likely your screen only draws 1amp, which is barely anything for your M4. I would say just run it off your M4 for conveniance.
nobb is offline   Reply With Quote
Old 10-21-2009, 03:14 PM   #5
Quote: Originally Posted by Larzfromarz View Post
Darque-
Keep em coming-
Larz
The PicoPSU is ATX-compliant. That means it doesn't provide power until it recognizes current on a certain pin (13, I believe).
That means you have to short that pin with a ground line with a bit of wire or somesuch for it to provide power.
That's kluugey in my book.
Never mind that if the wire or whatever you use to short pin 13 comes disconnected, you suddenly lose power for your screen. And that's not something one would typically look for in the process of troubleshooting.
I could see that situation being one that causes hair to be yanked out by the roots in sheer frustration.
Not something I'd want to deal with.
AMD AM2 CPU Low Wattage ACE General Hardware Discussion 21 06-11-2006 05:13 PM
Custom log parsing automation… xcntrk75 Software & Software Development 4 05-11-2005 03:19 PM
Arrrgh! Can't make up my mind about PS! Pred8tr Power Supplies 13 01-27-2003 12:22 PM
Converting AT PS to ATX PS? How to? Maveric Power Supplies 6 08-15-2001 10:50 AM
Arise ACE-865V dc-dc ps, system wont post, help... plasmadis General Hardware Discussion 7 07-17-2000 03:08 AM
