Old 11-04-2009, 08:12 PM   #1
davedave1234 is an unknown quantity at this point
Anyone Try one of these? (ROEM-X OEM Keyless Entry Input Circuit)
I just ordered it and was wondering if anyone ever tried it before? I did a search but came up with nothing.
http://curioustech.home.insightbb.com/remote.html
Thanks,
Dave
davedave1234 is offline   Reply With Quote
Old 11-04-2009, 09:10 PM   #2
Pathos's Avatar
Pathos is on a distinguished road
Never heard of it either........looks interesting, keep us posted
"A rose by any other name is still a flower"
Pathos is offline   Reply With Quote
Old 11-04-2009, 09:43 PM   #3
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Those are done by a user on this site, Curiosity, so if you have any questions, best speak to him
Enforcer is offline   Reply With Quote
Old 11-05-2009, 02:46 AM   #4
What can I say? I like serial.
Curiosity's Avatar
Curiosity will become famous soon enough
I've tried it. Those haven't actually sold much yet. People probably don't know what they are, but you're soon to find out. If you have any questions or need any help, you can always email me and I'll be subscribed to this thread.
XPort 1.41 -GPS port splitter, logger, and USB device resume fix
GPS DirectShow Filter / XOBD / MiniCam
Curiosity is offline   Reply With Quote
Old 11-05-2009, 09:07 AM   #5
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
might just have to be a guinea pig for this here! Subscribing!
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 11-05-2009, 01:01 PM   #6
Thanks, I will tel you know if I need anything. By the way does this kill the link to the ignition all together? meaning turning on and off the ignition no longer turns the pc on and off? not a big deal since I dont think I have ever used the key to open the door. But just wondering if there is a way to have both.
I will keep everyone posted as soon as I get it and get a chance to try it out, I realy hope it works out, since I had to rebuild my pc I desiced to try win7 and it is great and the sound quality of my onboard sound card is 10X better then with XP, must have better drivers. But the isssue is that it takes a little longer to boot up, (20 sec) and if this does work I will be able to start the PC before I get into the car and it should be at least closer to ready by the time I get in. The best part is that it works with your OEM keyless entry.
Old 11-05-2009, 01:11 PM   #7
Maheriano will become famous soon enoughMaheriano will become famous soon enough
I just checked it out, cool idea. Put some on Ebay, see if they sell.
Ampie Case
256 MB DDR2 PC5400
Xenarc 700TSV - VGA Monitor
Intel D945GCLF Motherboard
M2-ATX-HV
2005 Honda Civic
Maheriano is offline   Reply With Quote
Old 11-05-2009, 01:20 PM   #8
Curiosity's Avatar
It works both ways. Turning the key on and off will be the same. The remote unlock bypasses the key until you put the key in or press lock. Same goes for the wired button. There are also some other features like tapping the button and turning the key off to leave it on until you turn the key back on.
Old 11-05-2009, 03:11 PM   #9
Terminal flasher
Another question. Per your site
Quote:
Note: While the ROEM-P will automatically detect negative locks, it will consume 3.8mA instead of 2.2mA when idle, so request ROEM-N for negative locks.
does this mean the ROEM-P will work with both types of locks? I'm 90% sure my RSX is negative but if the ROEM-P works with both i'll go ahead and order it today
03 Acura RSX Coupe
Old 11-05-2009, 03:34 PM   #10
Curiosity's Avatar
Yeah, the P one works either way. That's probably the only one I should make since it's automatic. Also, the cheaper one comes with the button so just order that one.
Old 11-05-2009, 03:41 PM   #11
Terminal flasher
Ordered. Just when i think i'm all done with the car PC install someone has to put something else out there! lol
03 Acura RSX Coupe
Old 11-05-2009, 04:23 PM   #12
Toxic0n is an unknown quantity at this point
Looks interesting. I might buy this if I can figure out which wire is the lock/unlock wire on my aftermarket alarm. Seems simple enough to install and pretty cheap.
Toxic0n is offline   Reply With Quote
Old 11-05-2009, 05:03 PM   #13
See if your alarm outputs a pulse on any AUX channel, it'll do the same thing.
Ampie Case
256 MB DDR2 PC5400
M2-ATX-HV
2005 Honda Civic
Old 11-05-2009, 06:10 PM   #14
Curiosity's Avatar
Oh yeah, it is set up for momentary inputs, so a constant trigger won't work. The input can do single wire toggle though. AUX could be used to toggle it on/off. Or like I mentioned AUX and lock for on and off, or unlock and lock, or AUX to toggle and lock for off, or whatever.
Old 11-06-2009, 03:49 PM   #15
It does have an AUX channel but I am not sure if it is a pulse or momentary. It's a compustar 2wfm
Requests CdRsKuLL FreeDrive 118 08-11-2006 06:09 AM
Simply serial input circuit rando General Hardware Discussion 84 10-19-2005 10:29 AM
HELP, Input Signal to AMP Power_nisse Car Audio 4 06-22-2005 12:35 PM
Looking for help w/ modifying OEM headunit as input device. silencery Input Devices 9 12-09-2004 01:34 AM
Keyless Entry Shutdown Controller Sinorm Power Supplies 2 04-07-2004 09:30 PM
