Old 11-05-2009, 08:39 PM   #1
jhowle is an unknown quantity at this point
Need Help: 12V Timed delayed Auto on/off switch
Hello, i need some help. Sometimes when i turn my car pc on the screen turns on faster than the PC and the screen stays in standby because it doesnt since video signal.
The M2-ATX power supply has a user adjustable time delayed on off switch that starts counting once a 12v ignition signal is recieved. This is what i want to have happen when i turn on the PC. I want to delay power for the screen for approximately 3 sec since it just turns on when i gets power and hopefully it will stop staying in standby. Any help here is always greatly appretiated.
jhowle is offline   Reply With Quote
Old 11-06-2009, 01:31 PM   #2
Car Audio Moderator
durwood's Avatar
durwood is an unknown quantity at this point
Use the 12V from your m2-atx to power or turn on the screen. If you can't spare current from your 12V line, use it instead to tigger a relay which supplies 12v from the car.
What screen doesn't have auto sense?
System always under construction
durwood is offline   Reply With Quote
Old 11-07-2009, 01:28 PM   #3
it does have autosince but for some reason does this. I built a little box consisting of a relay and some switchs to give power to the computer. Basically i have momentary push button to start the relay and the relay stays closed after you relaease the button but only opens when you shut off the car. I wish to inside this box a smal circuit that basically does what i described and also rectifies the current to 12v.
Old 11-07-2009, 07:05 PM   #4
What can I say? I like serial.
Curiosity's Avatar
Curiosity will become famous soon enough
USB has quite a long delay. You could add a 5V relay off USB to trigger your latch. It might be half way into the boot, but would do the trick.
XPort 1.41 -GPS port splitter, logger, and USB device resume fix
GPS DirectShow Filter / XOBD / MiniCam
Curiosity is offline   Reply With Quote
Old 11-08-2009, 03:37 PM   #5
i guess that culd work but still i just wanna build something inline
Old 11-08-2009, 05:04 PM   #6
justchat_1 will become famous soon enough
Alot of motherboards will power on usb for a second or two as part of a self test when the system first boots and then cut power till the OS gains control. Better off just using the 12 or 5v line of the PSU.
openMobile - An open source C# Front End
- Currently Recruiting Developers -
Available for download on sourceforge
justchat_1 is offline   Reply With Quote
Old 11-08-2009, 05:47 PM   #7
Curiosity's Avatar
That's true. It will power up to check for bootable devices, but can be disabled. I also sell timers for this kind of thing. The M2-ATX should work for the supply though. Why aren't you using that? Search ebay for AX3022 and you'll see what I'm using for mine right now. It has a very clean output and it's cheap. I have it set for 12.1V and it has never cut out and always stays cool.
Old 11-09-2009, 11:57 PM   #8
do you know of anything i can build myself?
Old 11-10-2009, 12:43 AM   #9
Curiosity's Avatar
Sure. There are lots of on delay circuits. 4th one down here http://www.bowdenshobbycircuits.info/page2.htm
That was from an off delay thread a few days ago. I forget what it was for.
Old 11-10-2009, 05:30 PM   #10
cool, ty so much for your help. ill check it out. Thats what im looking for.
M2 pic chip? can we program custom times? 89ragtopgt Power Supplies 7 01-22-2008 09:24 AM
Usb Power On/off Switch kleicl Power Supplies 5 07-19-2007 11:27 PM
Capture GPS data at the flip of a switch Mr. Inquisitive GPS 4 02-02-2005 07:06 PM
Power inverter on/off switch question Skipjacks Power Supplies 41 01-22-2005 01:33 PM
Which wire is power and which is ground in Inverter on/off switch. Relay Question. wonderworm Power Supplies 13 09-20-2004 07:01 PM
