Old 05-02-2003, 05:05 PM   #1
ddt
Registered User
ddt's Avatar
Help with my tank circuit.
I built a tank circuit using this diagram:
I actually used (2) 2200MFD 50V caps wired in paralell.
I used an MBR3045 and went and hooked it up.
The computer wouldn't boot so I broke out the multimeter and while it was getting over 12V coming in it was only registering 3.18V going out (and into the PSU). So I decided to hook up a 1/2W resistor to it and charge the caps.
Well they get to about 10.5V and then go back down to 3 or so volts. And do so repeatedly. What's going on here? Help me!
ddt is offline   Reply With Quote
Old 05-02-2003, 05:13 PM   #2
The diode is reversed? (Your diagram is right, BTW.)
RobM is offline   Reply With Quote
Old 05-02-2003, 07:10 PM   #3
ddt
Registered User
ddt's Avatar
Well it was a short and I fixed it. After that my computer powered up beautifully and then for the test...
I started the engine... and the computer rebooted . What now?
Old 05-02-2003, 07:12 PM   #4
ddt
Registered User
ddt's Avatar
Quote:
What do you mean? How could it be reversed? A and A go to the battery and K goes to the cap(s), right?
Old 05-02-2003, 08:50 PM   #5
Quote:
Nope, your diode it connected right. You could try a few things. Replace the CAP with a small gel cell 12 volt battery, or replace the CAP with a 1 farad cap. Or, replace the Diode with one with less forward voltage drop.
Hey, where did you get that diagram?
-Jeff
MPEGBOX - Plexiglass Computer
www.mpegbox.com
zootjeff is offline   Reply With Quote
Old 05-02-2003, 09:22 PM   #6
ddt
Registered User
ddt's Avatar
Quote:
-Jeff
Here:
http://www.mp3car.com/vbulletin/show...5&pagenumber=1
but you probably already know that now.
Also, I just remove the caps and replace them with a small 12V gel cell wired the same way?
Also, you made mention of other diodes. I'm using a 250W Top Micro DC-DC Converter. Which diode would you reccomend?
I'm trying to get away from using a big assed cap due to space where I need to mount it. Would a .5 Farad cap work?
Old 05-02-2003, 09:26 PM   #7
ddt
Registered User
ddt's Avatar
On this page:
http://www.batterystuff.com/battery/batteries.htm
Would the ES 1.2-12 or the ES 1.9-12 be ideal for this?
Or what about this one?
http://cgi.ebay.com/ws/eBayISAPI.dll...&category=1200
Old 05-02-2003, 10:21 PM   #8
On this page:
Yes, just replace the Cap by the battery. I would go with the 4-12 but there is a chance the smaller ones would work..
www.mpegbox.com
Old 05-03-2003, 12:57 AM   #9
ddt
Registered User
ddt's Avatar
So I keep the diode? Is it really necessary with the 4-12 (which I just bought)?
Old 05-03-2003, 01:39 AM   #10
Yes you keep the diode. It is still important. Car cranking could still bring down the voltage at your spare battery if you don't have the diode.
www.mpegbox.com
Old 05-03-2003, 01:45 AM   #11
ddt
Registered User
ddt's Avatar
thanks man! You have been most helpful.
Old 05-03-2003, 02:11 AM   #12
Unregistered User
ODYSSEY's Avatar
Would there be a problem of overcharging the gel cell?
I came across this site. It talks about adding a limiting resistor to safely charge the gel cell.
ODYSSEY
Quote: Originally Posted by Tidder View Post
Digital-Car UK|
(\__/)
(")_(")
ODYSSEY is offline   Reply With Quote
Old 05-03-2003, 04:30 AM   #13
You don't need the resistor or the extra diode. That is being anal and isn't really nessessary. plus the "float" voltage the car puts out is well within the range of the Gel cell.
www.mpegbox.com
Old 05-03-2003, 10:11 PM   #14
DodgeCummins's Avatar
I don't know about this setup, but if you have two batteries hooked directly to each other and the alternator (like in my diesel truck) you need two batteries of the same capacity, or else one may get overcharged/fail/worse.
Perhaps having your battery on its own circuit and isolated might be different.
current projects
DodgeCummins is offline   Reply With Quote
Old 05-04-2003, 04:37 AM   #15
Quote:
How can you overcharge a wetcell battery that charges by having a constant voltage? I can see the argument about having too much inrush current if one is depleted (a smaller battery). If the two batteries are in parallel and they are of different capacities, one runs out faster, but the voltage at the terminals are the same for both, so all the current just comes out of the one with more capacity.
NiCads are trickle charged with a constant current, IE if you hooked a 1.2 volt nicad to a current limited 25 volt source, and set the max current to 50 milliamps, it could charge forever and not get hurt. Where as if you put a wet cell battery in this situation it would kill it after a while because it would try to charge to 25 volts.
So if I'm understanding it correctly, to charge it, you take a wetcell battery (like in a car) and you just hook it directly up to 13.8 volts, if the battery is low, it sucks a lot of current, it is the regulators job to not exceed initial current rating. So if you have two batteries, the regulator cuts out sooner, if they are different capacity, one will take more current, but they will both charge to the same voltage.
Can someone help me understand why you need Isolation? And why this is even a problem?
www.mpegbox.com
