I'm not a big fan of inverters, but until Opus releases their new 90watt power supply or someone else comes up with a new power supply to work with the Epia M, I saw this invertor:
75 watt inverter
I figured my Epia M with the Castronic 2699R case, 60 watt DC-DC power board (included) and the A/C adapter, should go with this inverter.
It looks small enough and it probably will not make as much heat (wasted energy) and noise as opposed to the larger bulky inverters.
What do you think..guys?
http://www.4lots.com/product.asp?0=203&1=209&3=95
UPDATE:
(1st test - Power invertor)Rayovac invertor 75w/150watt max.
Plugged it in, powered using the supplied 60 watt castronic A/C adapter, light came ON in the adapter, turned ON computer 2 seconds later...COMPUTER POWER LOSS.....I'm looking into what may be going wrong. It doesn't make sense but seems to be a power overload.
(2nd test - Radio shack 60 watt/12-27 volt in car universal notebook adapter) set to 12 volts.
Plugged in directly to castronic 2699R case, powered up and 2 seconds later - same power loss problem - I checked the inline glass fuse in the DC adapter and it was blown. I think the castronic power supply is drawing too many amps.
