Old 05-29-2003, 06:50 PM   #1
rbarr110
Where can you access the ignition power switch (IGN/SW)?
I know there is a line going to the car stereo but was wondering if there are any other points to access this line?
I don't really have the ability to pull the factory stereo easily, and to be honest don't want to pull out the stereo. So where else where I find the IGN/SW line to connect to my OPUS.
2002 Toyota Tacoma
Ryan
New site at
http://customcarpc.dreamhost.com
http://home.attbi.com/~rbarr110
2002 Toyota Tacoma Doublecab
rbarr110 is offline   Reply With Quote
Old 05-29-2003, 06:54 PM   #2
eCar™'s Avatar
eCar™
Go to the fuse panel. A lot of fuses only recieve power when the ignition is on (on most cars).
eCar™ is offline   Reply With Quote
Old 05-29-2003, 08:51 PM   #3
GezusK
Steering column too.
GezusK is offline   Reply With Quote
Old 05-30-2003, 08:28 AM   #4
DodgeCummins's Avatar
DodgeCummins
Some fuse boxes have a spot for ACC or IGN.
ACC is the position when your ignition is not on, but power is still available.
current projects
DodgeCummins is offline   Reply With Quote
Old 05-30-2003, 12:13 PM   #5
cproaudio's Avatar
cproaudio is on a distinguished road
Re: Where can you access the ignition power switch (IGN/SW)?
Quote:
2002 Toyota Tacoma
Ryan
you can access the accessory wire at the cig lighter in front of the shifter. check out rbarr110's install.
NEW complete and updated My project with 100+ pics on 7-4-03
If you have a Shuttle FV24 motherboard in perfect working condition for sale, please PM me.
cproaudio is offline   Reply With Quote
Old 05-30-2003, 01:23 PM   #6
rbarr110
Thanks for the replies. Got some ideas now where to look.
Cproaudio - The link you provided is an old one and not as up to date. Try this one and click installation on the left side.
New site at
Old 05-31-2003, 03:34 PM   #7
rbarr110
OK maybe a dumb question, but will any line that only receives power when ignition is on work as the IGN/SW line?
Ryan
New site at
Old 05-31-2003, 09:13 PM   #8
timothy
yes, just be sure to take power BEFORE the fuse, and then add a fuse of your own
1999 Grand Prix GT
o Alpine CDA-9811 w/ Aux In adapter
o CarPC control with no display (yet), using Bemused on my Nokia 6620 over bluetooth to control linux CarPC. Details coming soon.
timothy is offline   Reply With Quote
Old 05-31-2003, 11:23 PM   #9
cproaudio's Avatar
Quote:
No you dont want to do that You should tap it after the factory fuse. I have seen so many cars with burnt up factory wires by doing that and here's why. The back up fuse before the fuse box in the interior is the big 60A or 80A sometimes 100A by the battery. imagine if youre wire is shorted between the main fuse and the fuse you added. You're gonna have a fried wire from the fuse box to the battery. Beside The opus's acc wire takes only 150ma or .15amps. It's not going to add any more strain on the wire you tap it to. You should tap the wire after the factory fuse then add your own fuse. If you need any power larger than the factory wire can handle, you should go directly to the battery.
Rbarr to answer the "will any line that only receives power when ignition is on work as the IGN/SW line?" question is no. Some ign wires go to onboard computers or airbag system that you dont know about. or to the wiper. It works fine until it starts to rain. You should stick with radio, cig lighter or the clock. Since you got 2 cigeratte plugs on that panel you already took off, you can tap the acc wire there. white/black is ground on Toyotas, brown on the radio is ground too. as for ACC, Toyota change colors once in a while.
