The MP3car.com Store
Thread Tools Search this Thread Display Modes
Old 05-31-2003, 04:48 PM   #1
My Photos: (0)
tank circuit - what output do I need?
I'm building a tank circuit, but I don't know what the output amperage needs to be?
Also I am plugging the output of the tank circuit into this other circuit which regulates my 12v power source. What output amperage should that need?
Here is the tank circuit I'm building:
And here is the regulator I'm building:
(ill upload later)
What voltage and amperages do I need to make sure I have for the output. I have the 55w DC-DC PSU that comes with the Cubid cases.
Thanks,
Kevin
maxcosity is offline   Reply With Quote
Sponsored Links
Old 05-31-2003, 11:37 PM   #2
My Photos: (0)
Umm the amperage will vary on your car based on what your running.
The voltage of the output of the tank circuit will be whatever your car is. What the tank circuit does is when you crank your car up and its running at like 14v the capacitor stores this voltage so the next time you crank it wont drop that low.
The ouptut of the regulator would be 12v, since it regulates the voltage.
Mp3Goose_Your King is offline   Reply With Quote
Old 06-02-2003, 12:13 AM   #3
My Photos: (0)
Can I use both of these circuits -- in series to one another?
Also, where can I find some of this stuff.. I picked up some caps from Radio Shack but they didn't have the right diodes (I don't think), the semiconductor, or the bigger caps (22,000 or even half that).
Old 06-02-2003, 06:38 AM   #4
stimps's Avatar
Vehicle: 2002 Ford XR6T
My Photos: (0)
alternative tank circiut.
I've got a untested but SURE to work idea, because its so simple. You need a large germanian diode. (dick smith stock it) and a small 4Ah SLA or something similiar. Hook up the cars positive power to the germanian diode, so it goes thru that, to the positive of the small 12volt battery. Then run your power feed to your DC to DC supply off that. When the car is off, the computer can draw power from the battery, and if it drops low enough, will draw power from the vehicles battery also. When the engine is running, more than enough voltage will come thru the diode and top up your SLA battery and run your PC. Then if you stop it, and crank the motor, the vehicle battery will drop to 10 or even less volts, but your dc to dc supply will still recieve 12 volts or so and not even notice the cranking.
Obviously, you ground your power supply to the car, and the sla battery also. The sla battery will be good enough to run your PC for 5 mintues or so, but i dont think you will ever crank your engine for that long!!
Like i said its untested, but ill test it soon. Its so simple it has to work:P
stimps is offline   Reply With Quote
Old 06-02-2003, 09:48 AM   #5
My Photos: (0)
yes, please try that out and let us know what you find!
Old 06-02-2003, 10:54 AM   #6
dansoton's Avatar
Vehicle: Ford Focus 2002
My Photos: (0)
Firstly can I appologise for being really ignorant and stupid about electronics but, in the diagrams above the positive terminal from the batteries are connected, but the negatives just goes to ground - surely this means the circuit is open and so won't work? Obviously it does work, but I just don't understand why...
Many Appologies in advance!
dansoton is offline   Reply With Quote
Old 06-02-2003, 01:23 PM   #7
My Photos: (0)
What's missing here, because this is VERY COMMONLY UNDERSTOOD in the automotive world, is that GRN is actually hooked up the the battery's (-) terminal.
In fact, on just about every car, the chassis (metal) is ground and it is hooked up to the (-) terminal on the battery. This allows you to shorten the length of your ground runs, saving wire and making it safer for electric components to be run in a car with sharp metal corners, etc..
So the circuits DO work, you just need to ground to the (-) on the battery (all cars are like this from the factory - don't worry about this).
Old 06-02-2003, 02:43 PM   #8
PTCruiser's Avatar
Vehicle: PT Cruiser Ltd Black
My Photos: (0)
LT1084IT-12 is a low drop out linear regulator...
That mean to get 12 V regulated you need Vin >12V...
So it will not work engine stopped...
Epia M9000, lili 7" vga&touch & 2xTM-7002S compo, camera with reversed image, 2.5" 60 GB, 256Mb DDR, Opus 90W, GPS usb... AND MEDIACRUISER of course!
PTCruiser is offline   Reply With Quote
Old 06-02-2003, 03:30 PM   #9
My Photos: (0)
Right which is why I said I would be plugging the 22000uf cap circuit (1st diagram) in and have the output into this tank circuit, therefore the "engine will never stop" (in other words, there will always be usable voltage coming out of the 22000uf cap while the engine cranks.
Although you do bring up an interesting point, that is, I wonder if this cap will supply 12v or if it will supply more. It's rated at 25v so perhaps it will just use 25v when it "discharges" into the tank circuit when the engine is cranking.
Old 06-02-2003, 06:26 PM   #10
Vehicle: 04/Acura/TL/6MT
My Photos: (0)
This was all talked about and tested here:
http://www.mp3car.com/vbulletin/show...t&pagenumber=1
MPEGBOX - Plexiglass Computer
www.mpegbox.com
zootjeff is offline   Reply With Quote
Sponsored Links
Old 06-02-2003, 06:37 PM   #11
My Photos: (0)
Yeah, it kind of was, but I was unable to get the right capacitors and so I was hoping if I knew what I needed to end up at, I could reverse engineer what I needed.
It looks like I need 12v+ and 5amps on my output, does that sound about right? I've got the 50w DC-DC PSU that came with the Cubid case.
I think as long as I find the right components I'll be ok..
Old 06-03-2003, 09:29 AM   #12
GingerPrince's Avatar
Vehicle: 1996 TVR Griffith 500
My Photos: (0)
Re: tank circuit - what output do I need?
If you're going to use my circuit drawing from my website, please don't link directly to my website and eat my bandwidth. Copy it to your own website and link to that. Bandwidth costs money.
Also, no reference to where you "nicked" the diagram from. Netiquette, please.
Sy
GingerPrince is offline   Reply With Quote
Old 06-03-2003, 11:28 AM   #13
My Photos: (0)
sorry - fixed.
Old 06-03-2003, 03:06 PM   #14
My Photos: (0)
Re: Re: tank circuit - what output do I need?
Quote:
Sy
You are fussing about a 9k image? How much is your bandwidth costing??? Where is my credit for the tank circuit? I was the first to post any kind of information about a tank circuit to this board. I don't see anyone sending me thankyou cards in the mail.
PS: .gifs are better for mono graphics..
if I choose the right diode and made a circuit board for it etc. If I put on my website would anyone buy it for 10 bucks or so?
www.mpegbox.com
Old 06-03-2003, 03:47 PM   #15
My Photos: (0)
Quote:
Originally posted by maxcosity
sorry - fixed.
no problem fella
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
Sponsored Links
Ad Management by RedTyger
