Already looked in the BIOS there were no usefull options I could change.
The scandisk issue is already done.
This is the only real problem I have got with the laptop - what other issues were you refering to? as long as it is powerfull I would have thought it was prety much ideal.
It is afterall basicly a PC but with smaller parts designed to run from a relitivley low power source.
I suppose if you wantedc to use it lots then disconnecting it from car all the time would get annoying, (although its only 3 wires) but as I dont use mine too much its ok.
I would have liked to use the carputer i originaly built but as I said I had to borrow parts on it. But I would say that also had issues some major issues! One of the main being that the fans in it and in its PSU were so damn noisy! Also it wasent as small as I would have liked it to be.
I had a bit of a search around the forum and saw that somone has got past this problem by simply:
Sticking the power button down and taking the battery out so when the inverter turns on so does the laptop
(I already have the inverter wired so that when key is tunred in the ignition it turns on. So that may be a good soloutiuon.
Although any other ideas would be appreciated!
Thanks for the reply!
Chris
