Auto navigation. Using a bunch of sensors and some servos, I have it setup to steer my car keeping it in the lane and control the speed so it doesnt run into anything while scanning cop frequencies to avoid tickets. Not really, but maybe in the future.
I played around with it some more yesterday. I took a free connector from the PS and wired the 12v pins to the aux connector. It booted on the first try. Just to be sure, I unhooked the cable and reboot. Again, it became unstable and refused to boot. Although, the Opus doesn't put out enough 12v amps, maybe the cable will be enough to stabalize it. I'm picking up a connector/adapter for it shortly and will post results.
But my question still stands, anyone know the best way to power the 12v aux connector via a dc-dc device?
I would probably need about 6amps of clean 12V power. Any ready-made solutions available? From my research on google, I found that most regulator chips need a slightly higher input that output voltage. So for clean 12V, they need an input voltage of at least 13.5 but can range upto 48v. But in a car, the voltage can range from under to over 12V depending on load. I wonder how Opus tackles this? Maybe invert the power to a higher voltage before applying a regulator. Unfortunately, the only electrical engineering course I took was an introduction level and we focused on computer architecture. I may ask some EE majors at school for help.
