Notices
Old 06-26-2003, 12:03 PM   #1
how do I make my inverter automatically on and off?
I would like to make my inverter turn on when I turn the ignition on and turn off after I turn off the ignition. How do I do that and what parts do I need? Thanks.
e36mp3 is offline   Reply With Quote
Old 06-26-2003, 12:44 PM   #2
Self proclaimed spoon feeder
TruckinMP3's Avatar
Search for relay and inverter.... then read
TruckinMP3
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
Old 07-01-2003, 11:40 AM   #3
Registered User
Skraggy_uk's Avatar
Yep, used a relay, but mine works off the Headunit antenna/remote line.
The relay is fitted into the fused inverter red wire that goes to the battery, and is triggered when you switch on the Headunit.
4x4 in a turbo stylee.
Skraggy_uk is offline   Reply With Quote
Old 07-04-2003, 09:03 PM   #4
cubanmoses's Avatar
man, i was about to post something on this, but i found wha ti was looking for. that's the same wire i have my lcd polugged into and my radio, if i connect the power inverter to that wire, would that be fine?
also, i got one of those car/airplane power supplies, so i can remove the car adapter and two wires are there. i rather not cut the wire and void the warranty in case comething ever happens to the power inverter, so can i rig some wire to go to the remote wire from the power inverter?
project: built, updating software
comp: 1.67 ghz AMD, 1 gig of ram, 80 gb hd
software: nlited xp, roadrunner
screen: TM-701L touchscreen
bluetooth keyboard
Sony Xplod cdx-m630
SB MP3 sound card
future: gps with and navigation software
cubanmoses is offline   Reply With Quote
