Quote: Originally Posted by e_fractal
You can try a .5 > 1 farod cap used for car audio to keep the current up while cranking, if that is your problem. 1 farod would be overkill, but half farods are hard to find (for me anyway).
But .. how do turn on your PC? It could alao be a problem with a remote wire off your ignition, pending how you hooked it up.
I have it wired into the fuse panel under my driver side dash. it has 3 connectors for a spade connector. one is always hot, one is hot when key is turned to ON, other is hot when headlights are on. I have it wired into the one that becomes hot when key it turned to ON.
