08-25-2003, 05:40 PM
#1
Registered User
Sprrogy MK3.0 comming soon.!!!
Hello friends ,
Just completed the MK3.0 design. and received the PCB for it. shall test it in the next 24hurs and post the result here with ALL details.
Spec:
3.3vdc --- 5amps
5vdc -----10amps
12vdc-----2amps
-5, -12, stby everything on ... full ATX features......
"NO MORE t6"
ISOLATE THE MBR745 AND THE MTP3055 ON THE HEAT SINK
CHANGE THE IN5819 TO IN5822 SORRY ABOUT THAT.
Cheers
Mastero
08-25-2003, 08:49 PM
#2
does that mean the parts will be easier to get?
how much of the old parts can be used witht he new setup?
i got a few of the parts just never got the rest of them to finish the older version
WINNER!!!!
run-on sentance comp 2002!!
08-26-2003, 03:39 AM
#3
Registered User
Please wait for a while shall post all details up here with components list
Mastero
08-26-2003, 05:22 AM
#4
Mastero
Ooh, I can't wait. I feel like a child at christmas!!!
Current Cfg: AMD 2200+, Epox Mobo, 7" Lilliput TS, 320MB RAM, 40GB 2.5" HD, 200GB SATA, Slim Combo, ATI Radeon, SMC B/G Wireless w/ 5dB antenna, Bluetooth.
S/W: RoadRunner/MapMonkey/NetStumbler. Still working on a box and PSU!
08-26-2003, 06:53 AM
#5
Do you like?
Hi from Spain, Do you like it?
Description/Specifications
Dimensions (mm) 160 x 45
Input Voltage Required (V) 11.4V~12.6V
Maximum Output (W) 62.4
Output Voltage V 5VSB +3.3V +5V +12V -12V
Current A 1.5 4.0 4.5 1.5 0.1
Power Output W 7.5 13.2 22.5 18.0 1.2
Peak Current A 2.0 8.0 8.0 2.0 0.2
I have got one unit and is perfect to mount in a car. Price 30€.
Taluego...
08-26-2003, 08:41 AM
#6
Raw Wave
Your car voltage will go up to 14.4V, thereby breaking the input voltage requirements. This is not very suitable for car use without a regulator on the input. This has been covered many times before.
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 8Gb flash DOM, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
08-26-2003, 09:09 AM
#7
Marvellous, give us an update ASAP please Mastero
Regards,
nick.
08-26-2003, 11:09 AM
#8
But with a lm78L12 I can regulate the voltage to 12v. It works to me perfectly. Hasta luego
08-26-2003, 11:21 AM
#9
Raw Wave
The 78L12 is a 100mA regulator, which is not enough. In addition it is a linear regulator (and requires the input voltage to be higher than the output by about 2v). Again, this has been covered many times before, I'd recommend you do some reading.
08-26-2003, 11:48 AM
#10
Yes, it does work, provided you dont run any 12 volt accessories. Running a regulator will drop you down to some pretty scary voltages which could give you some equipment problems down the road.. I had this setup just to see how it worked and my biggest complaint was that it will not ride thru starting up your engine, this is a major pain... Not a bad cheap solution, but not perfect..
08-26-2003, 12:44 PM
#11
Raw Wave
Quote: Originally Posted by mikeinsanmarcos
Yes, it does work...
With a 100mA regulator, I think not... <flap flap oink>
With something more beefy, yes (with the problems you indicated).
Rob
08-26-2003, 01:30 PM
#12
yah, you are right rob.. I think I was using four LM2940 12 volt 1 amp regulators to power my setup..
08-26-2003, 05:27 PM
#13
Registered User
hey guys ... I was talking about a new Sproggy ... where have you taken my post ....
08-26-2003, 05:39 PM
#14
Registered User
you think this new PSU should be called something on the order of the MasteroPSU 1.0 ????
i mean, you basically redesigned the supply... right. i give credit to sproggy for the original designs, but i think you might deserve a bit of "naming rights" as well.
~mike
Single Member of the "1000 Post and No MP3 Car" Club
PROJECT ON INDEFINATE HOLD... BOUGHT A HOUSE
2000 Cavalier Z24 [###-------] Only 30% Done ... Still
08-27-2003, 02:46 AM
#15
Registered User
mp3z24 its a nice taught, but you ses the name "sproggy" is like a brand and everyone in this feild knows what they are looking at.
I like to keep it this way. Ofcourse on the PCB there will be mastero written also
Mastero
| Thread Tools |
| Display Modes |
Linear Mode
