I second that - the white/green wires MUST be connected to the motherboard's Power On connector in order for my Opus 150 to turn on (as I discovered the hard way myself). This is stated clearly in page 5 of the manual . You have to wait something like 5 seconds after applying +12V to the Yellow (Ignition) wire before it does this though.
If I disconnect the white/green wires from the Opus, all I get is 2 blinks on the green LED in the Opus. According to the manual, this means that the "power up sequence failed" and it asks you to check that the 2 pin power switch (white/green) cable is connected properly.
Once you install the Opus, there shouldn't really be a need to have a manual on/off switch connected to the motherboard. Just control the power to the PC using the yellow Ignition wire and the Opus does the rest. However, there are the rare occasions when the Opus is not able to shutdown the PC, eg when a rogue application prevents Windows from shutting down. In this case, my shutdown controller cuts off power to the Opus after 2 minutes to avoid draining the battery.
