Notices
Old 11-27-2003, 02:05 PM   #1
Simple & Tested Tank Circuit
OK, seen a lot of dodgy tank circuits on the forum, especially the capacitor based ones - that will rarely work ( only if you have a v good battery and a 1farad cap will it make a difference )
This solution uses a Yuasa NP 1.2Ah 12V battery as the "backup" supply, charged via a 10ohm resistor, the manual for battery says you do not need this resistor as the battery internally limits charge current - but I want to be on the safe side.... ( the battery will charge untill it 'floats' at the same voltage as the main battery....
Always uses lots of fuses
Try to use 0.4V drop diodes, and a 10W+ resistor
This battery will provide enough power to keep an EPIA + TFT alive for a good 10minutes if it takes that long to crank your car though i'd get a new one !
This circuit works and has been tested - the battery could be charged better by using an L200 regulator - but for the £4 i paid for battery I don't mind a shorter life
IMPORTANT NOTE: while this circuit works fine for me - use your common sense whilst building such circuits - use this as a guide only. Incorrect circuits can cause overcharging and may lead to a fire - ( which is bad in a car ) Please take care and test under supervision on the bench....
Jamez_Warner is offline   Reply With Quote
Old 11-27-2003, 03:09 PM   #2
Raw Wave
Good post jamez...hope the capacitor tank discussion will disappear
Yup yuasa datasheet says you dont really need a limiting resistor, I didnt like that idea either just incase the battery have internal short and drains lots of current.
Does your battery get charged fully? since you have 0.4V drop before the voltage get fed to the backup.
Ricky327 is offline   Reply With Quote
Old 11-27-2003, 03:14 PM   #3
yes, resistor is a safety measure ( allthough swapping this for a 4A fuse would do same job ) recommended float charge is 13.5V, car gives out 14.5 when running - ( my diodes are 0.8V drop atm) which gives a 13.7V float ( near enough )
just installed in car - and has stopped pc rebooting - works perfectly...
Old 11-27-2003, 03:22 PM   #4
Raw Wave
Good to hear that...I only expect about 13.8V from a car running. What PSU you feeding that into? Im using a DC-DC converter and I cant afford to loose any voltage at all...it dies when the supply goes below about 11.5V
With the capacitor :
1 farad capacitor? I dont even think thats big enough...less than half a second you get on 1F at 5A drain. No one seems to have proved they managed to succede with it.
Old 11-27-2003, 03:27 PM   #5
yeah - the 1 farad only works if you battery has a low voltage drop while cranking anyway ( the bulk of current of a crank is drawn in first few milliseconds - cap compensates for this and battery is enough to keep pc alive through rest of crank) but car batteries are rarely this good and i haven't heard of anyone being succesful with a cap
im using a morex 55w DC-DC psu, it too trips out at about 11.5V ( but at below 12V the HDD usually spins down causing a crash )
this also means you can change you main car battery with your PC still on if you are particulary addicted ! rofl
Old 11-27-2003, 04:18 PM   #6
SuperSonic's Avatar
Correct me is I'm wrong, but this circuit will provide backup battery power AND main battery power right? What I am suggesting is that running the PC with the engine off is no problem (it's not just limited to the capacity of the backup battery alone in this setup)
So you could easily run the PC for say 2 hours with the engine off?
Won't the downside of this be that you will probably drain your backup battery in the process, thus killing the PC when cranking after that?
Nice design!
SuperSonic is offline   Reply With Quote
Old 11-27-2003, 04:46 PM   #7
the backup battery runs about 2v lower than the main battery - running the PC with the engine off will drain main battery for 90% of the time, but will switch to backup power when main battery is partially discharged ( then both will go down together )
I don't think this would ever be a problem though - and your backup battery can never be lower than your main whatever happpens
Old 11-27-2003, 04:58 PM   #8
OdysseyPC's Avatar
It is true that you would be able to run the PC while the engine is off and provided you have a big enough battery (12Ah+) it will last about 2 hours. I currently use a very similar circuit to this which also powers a Morex 55W DC-DC unit.
I have one extra modification in that i include an automatic shutdown that monitors the battery level if it drops below 11.9V (easily variable) it shuts down the PC to ensure i have enough juice for the next crank.
Because it is often on display i use an 18.2Ah which keeps it chugging for just over 3 hours.
I'm currently in the progress of designing a modified sproggy that has the tank circuit and automatic shutdown all on one board, it's taking a while because i like small things (i.e small boards) and Protel DXP's autorouter likes big things so it is taking some time. Hope to post it soon.
Just to summarise:
* Yes you could run the PC for long times with the engine off
* There is a solution to preventing complete battery drain
Caputer Mk. II
'02 VX Holden Commodore Series II Executive
MII12000, 512MB RAM, 60GB HDD (5400rpm), 16X DVD, TS200V
Morex 60W DC-DC, Custom S/SDC
OS/Software: Developing...
OdysseyPC is offline   Reply With Quote
Old 11-27-2003, 05:03 PM   #9
odysesy - this circuit is just for powering the PC while you are cranking engine - for about 2 secs - need a tiny capacity battery - you are thinking of a full size dual battery system - if my key isn't in ignition my PC gets shutdown and relay turned off so no current draw....
Old 11-27-2003, 05:11 PM   #10
Raw Wave
Protel is cool, I been using it since 1994. But its still cleaner to manually reroute certain parts you are not too happy about...or route everything manually if the project is not too big. Im sure your circuit is not too complex.
Old 11-27-2003, 05:34 PM   #11
OdysseyPC's Avatar
James - I'm with you on that one. Just showing that your circuit, though simple, is all you need for preventing rebooting when cranking. I should've pointed out that my mains battery is only connected when the accessories line is high. This prevents the main battery drain when the engine is off.
Ricky - I too have been using Protel for some time during my degree and regardless of circuit complexity i continue to find this strange urge to press the autoroute in the vain attempt that one day, just one day, it will get it right.
Alas, as you pointed out, it did not and so i pressed the ever faithful 'undo' and proceeded to interactively route.
Caputer Mk. II
Old 11-28-2003, 03:00 AM   #12
PTCruiser's Avatar
Could you explain the goal of the diode in // with the 10 ohm resitor?
thx
Epia M9000, lili 7" vga&touch & 2xTM-7002S compo, camera with reversed image, 2.5" 60 GB, 256Mb DDR, Opus 90W, GPS usb... AND MEDIACRUISER of course!
PTCruiser is offline   Reply With Quote
Old 11-28-2003, 04:23 AM   #13
diode is to allow full current out of battery when its not charging ( current in limited / current out unlimited ) ie: when the engine is cranking and the backup needs to deliver 10 odd amps to PC/TFT....
www.digital-car.co.uk - The UK CarPC Forum
Old 11-28-2003, 04:27 AM   #14
the resisitor is to limit charge current ( you don't really need though )
Old 11-28-2003, 05:09 AM   #15
PORTUGAL's Avatar
Some people say that the opus can run the computer with the engine of for a couple of hours and still be able to start their car....
How does the opus do that???
Here in Portugal we have great weather, lots of brunnets, party a lot,drink a lot....
http://img138.echo.cx/img138/896/bannerjoshua5dy.jpg
PORTUGAL is offline   Reply With Quote
Newbie has a question about Tank Circuit. GScherler Power Supplies 1 11-14-2003 05:15 PM
tank circuit TiTUS General Hardware Discussion 10 09-07-2003 06:05 PM
tank circuit - what output do I need? maxcosity Power Supplies 16 06-03-2003 05:00 PM
Help with my tank circuit. ddt Power Supplies 16 05-05-2003 11:41 PM
simple LED circuit.. did i do this right? ShinkunoNamida Off Topic 5 06-04-2002 01:23 AM
