Jamez,
I made a circuit almost identical to yours (except with a diode, similar to Mike Carr's design,) and it has a problem with the cap discharging and sending a second pulse a minute or two later. Let me know if yours works. I even spoke to Mike Carr about it and he admitted that he had no idea, he just copied the circuit from someone else himself.
What is the blue thing above the resistor in your design?
SuperSonic,
Your controller doesn't send a second pulse and shut down the computer a minute or two after starting? Do you mind if I ask the exact specs of the parts you used? My circuit is only half that design since I only need the startup pulse, but I think it should work anyway.
Thanks.
