Notices
Old 12-20-2003, 06:34 PM   #1
Angry I have searched. How do I start up this laptop.
I have everything I need for my carputer.
I'm using a laptop and I had HOPED there was a port replicator made for it that would allow me to tap into its power button. There is not.
I need to be able to turn on my laptop from inside the car without having to press the power button. I can't open up the laptop to solder on the button points because the laptop isn't mine.
I've searched for a wake on lan option but couldn't really find a way to trigger a packet through a hardware device. The laptop does support this option though.
Am I completely out of luck?
I would love to be able to power on my inverter with a switch and have the latop sense A/C power and turn on.
The laptop is a Toshiba Satellite A15-S1292. The inverter is a 400W from Best Buy.
Please help me! I feel like I've hit a wall here and am very frustrated.
Audamn is offline   Reply With Quote
Advertisement Sponsored links
Old 12-20-2003, 06:58 PM   #2
jol
jol's Avatar
look into comport-on, might be used for old modems, a bit less tech than wol I think...my best advice
My cars
jol is offline   Reply With Quote
Old 12-20-2003, 07:00 PM   #3
bornagaincomput's Avatar
Try using the hbernate mode funtion and start it up through a wireless mouse.
Alpine 6.5 inch deck -1003
Diamond Amp
Eclipse sub 12''
Cliff Design Speakers
146 db of pure bass
bornagaincomput is offline   Reply With Quote
Old 12-20-2003, 07:01 PM   #4
Banned
NightHunter's Avatar
You probably cant get a port replicator but. I would keep looking in to the wake on lan thing. Most computers if when not shut down after use and the wake on lan is turned on, will come back on automatically when power is restored. Just dont shutdown your computer and cut the power to the inverter when done. There is no need to shut it down anyway, accept to save any unsaved data you may have or to save settings that may have been changed.
GOOD LUCK
NightHunter is offline   Reply With Quote
Old 12-20-2003, 07:10 PM   #5
Look for it in bios? I have a wake on lan option but that's all. Even being able to touch the screen to power up would be awesome. Anything outside of opening my trunk every time I want to boot would be good.
Old 12-20-2003, 07:51 PM   #6
Altimat's Avatar
Just use standby and you can start it with the touchscreen.
2002 Nissan Altima 3.5 5 Speed Bose FM/6CD ED E12A P4 2.26 512 Ram Ti4600 CDRW DVD Lilliput 200mW 802.11b Trackman AutoTap GPS Opus 150 Carnetix 1260
2005 Nissan Titan SE Dell GX-150 P3 1.0 512 Ram 20G GF4 MX4000 USB 2.0 DVD/RW Xenarc GPS Trackman
Altimat is offline   Reply With Quote
Old 12-21-2003, 12:24 AM   #7
Open the case up and solder a pair of wires to the switch or where it attatches to the board. Connect the other end of the pair of wires to a momentary switch near your seat and you're golden. The wires can be very small since no current is really flowing through them, and if you put some form of quick disconnect on them, you will still be able to remove the computer from the truck and use it normally. It's not really as hard as you're making it.
2006 Chevy Colorado: VIA M10000 EDEN, 1 GB RAM, 80 GB 2.5" Seagate HDD, USB Slim Slot DVD/RW, Holux GPS, MobileVU 10.4" LCD (touch not working yet), VOOMPC Case (blue), 70W DC-DC supply.
Jackso is offline   Reply With Quote
Old 12-21-2003, 04:57 AM   #8
Raw Wave
Rob Withey's Avatar
I don't think Audamn was saying that it was hard to do. I believe he was saying he couldn't do this because it was someone else's laptop.
Systems retired due to new car
Rob Withey is offline   Reply With Quote
Old 12-22-2003, 02:32 AM   #9
Ah, I missed that, I formally retract any statements previously made. However I add, that the vibration on the HDD probably isn't the best on a borrowed laptop.
Old 12-23-2003, 12:10 AM   #10
Red face laptop restart
I am also running a laptop for my carputer. My computer doesn't wake from standby with the mouse movement (touchscreen). Only route I see is to keep the pc on. I have a dc-dc for my laptop and run straight 12vdc to the LT. Any other suggestion for this? TIA
greddy0 is offline   Reply With Quote
Old 12-23-2003, 01:04 AM   #11
deadweasel's Avatar
How old is the laptop, and what OS are you using? If it's running 98, you will want to upgrade it as far as possible (OS) without killing it. If it's 2k or XP, you may be dealing with a problem that requires updating your drivers or windows service packs.
The ALEXIS Project
MP3---VIDEO---GPS---REARVIEW---OBD---SKINNING
Color Coding :
DONE / MOSTLY DONE / BASE FEATURES / WORKING CONCEPT / NO CODE COMPLETED
deadweasel is offline   Reply With Quote
linking into laptop power button corsamel General Hardware Discussion 18 09-06-2007 10:47 PM
Simulating laptop functions corsamel Software & Software Development 2 05-20-2004 03:41 PM
New to carputers. Old laptop + lilliput screen OK? NS98GSR Newbie 11 12-02-2003 08:29 AM
Ahh help laptop boot? adrian_uk17 Power Supplies 3 06-05-2003 04:01 AM
Should I switch from DC-DC ATX to laptop? dmbrown73 General Hardware Discussion 2 03-05-2002 01:24 PM
