Shamir,
Quote:
so you know how the RS thing has a tip that replicates the C134 tip? how do you keep using that if there is a shutdown controller between the voltage regulator and the computer
I cut it off and connected new wiring from the output of the RS regulator to the input of the ITPS.
Quote:
is bypassing the regulator on the ITPS difficult, or is it just a jumper pin setting
..well, sort of. The ITPS has a "solder bump" (actually 2 bare pads on the PC board) that is supposed to let you drop a glob of solder on it to bypass the regulator. For some reason it was difficult to get the solder to stick to it. So I just glopped a drop of solder between the pins of the regulator IC...same effect. So now, the 12v regulation comes from the RS regulator.
Quote:
how often do you go through scan disk on startup
It's only happended twice. The problem with the ITPS design is, if you turn on your car for a short period (I needed to move my car inside my garage from the driveway the other night...about a 20sec task) and then turn it off WHILE WINDOWS IS STILL BOOTING OR STARTING SOME APPLICATIONS, the ITPS will send the "shut-down" command 5 sec after you turn the ignition off, but windows doesn't "see" this command since it's still booting. As it continues to boot, the ITPS will shut off 12v power after 45sec. This is right in the midst of some disk access.....not good.
Anyway, some people have added and external "keep off" switch to prevent this type of situation, but I haven't....yet.
Quote:
That is, other than convinience, do you think ITPS is necessary
It is a convenience, but a BIG convenience if you use the carpc every day, every time you drive..... worth $40 to me.
