Notices
Old 12-28-2003, 12:02 PM   #1
does anyone have a shutdown controller design they can share?
I want to build my own shutdown controller, does anyone have any schematics for one?
Pontiac Grand Am
building CarPC useing BookPC and Lilliput 7 inch TS.
djrkd is offline   Reply With Quote
Old 12-28-2003, 05:30 PM   #2
Check out page 14 of this
MikeH
MikeH is offline   Reply With Quote
Old 12-28-2003, 05:53 PM   #3
mst
mst's Avatar
Thumbs up
Thank you very much for your link,it is a MUST read for all with Epia Mini-Itw motherboards
mst is offline   Reply With Quote
Old 01-01-2004, 02:07 PM   #4
is that just a shutdown controller? or also a tank circuit?
Pontiac Grand Am
Old 01-01-2004, 02:20 PM   #5
DJ
Are you referring to the ITPS? It is a turn-on/shoutdown controller plus a (somewhat unusable) 12V regulator. As I understand, a "tank circuit" usually consists of a diode feeding a large capacitor, which attempts to hold enough charge to continue feeding 12v to you carpc during engine cranking. The ITPS DOES NOT do this. However, they have recommended the following as a way to help overcome the crank issue. This approach should work much better than a capacitor:
MikeH
Old 01-01-2004, 08:39 PM   #6
Raw Wave
MikeH,
Some has already tried this solution, and surprised the ITPS barely work. This is due to the fact that the ITPS already need 13.3V atleast to output a regulated 12V, loosing another 0.6V throught the diode make the matter worst.
The battery symbol is drawn funny
Ricky327 is offline   Reply With Quote
Old 01-04-2004, 02:49 PM   #7
i just want a design simmilar to jeffs...
Pontiac Grand Am
Old 01-05-2004, 04:24 PM   #8
Ricky
Agreed, but I have bypassed the onboard 12v regulator. I'm using the laptop (Radio Shack) regulator before going into the ITPS. Therefore, there should only be a .1v drop across the switching FET on the ITPS. If my backup battery is fully charged, I should be able to get 11.3v+ or so (marginal, but should keep the mobo from rebooting) at the output of the ITPS during cranking. Obviously, I haven't tried it yet, so I'll let you know how it works when I do.
Yeah, looks funny to me too. It should have more cells...looks like an asymmetrical capacitor.
MikeH
Old 01-12-2004, 05:10 PM   #9
all i wanna do is build a fairly simple shutdown controller.
Pontiac Grand Am
Old 01-14-2004, 05:01 AM   #10
moahdib's Avatar
Check out my "old" mp3car project page. In the hardware section you should see Jeff's shutdown controller (original) which I built a first working prototype of and its schematic.
http://home.comcast.net/~danielsoh/shutdown.htm
04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
Fast car, fast PC. ;)
http://www.arcdesigns.net/carpc/
My TL CarPC ver2
FSR Flash Skin w/ moving weather maps
moahdib is offline   Reply With Quote
Old 01-15-2004, 12:48 PM   #11
thanks alot, exactly what i was looking for. I got one question, i tried to add the "2N3904-ND NPN SML SIG G.P. AMP&SWITCH TO92" to my shopping cart on digikey and they dont have that exact product. Which one of these would be the best substiute? http://www.digikey.com/scripts/DkSea...S&Cat=30999646
Pontiac Grand Am
Old 01-15-2004, 01:12 PM   #12
moahdib's Avatar
This one should do.
http://www.digikey.com/scripts/DkSea...=65442&Site=US
My TL CarPC ver2
Old 01-15-2004, 03:05 PM   #13
Raw Wave
MikeH,
No I meant it was drawn upside down
Old 01-17-2004, 04:39 PM   #14
got recommendation for a good bread board for it?
Pontiac Grand Am
Old 01-17-2004, 08:46 PM   #15
henkbliek's Avatar
Quote: Originally Posted by Ricky327
MikeH,
Exactly, this way of connecting stuff might give the carpc a typical R2D2 response. Whhheeeeee... and emit some smoke
white bream
working on a trilogy: CARGO - UNIGO - MERGO
CARGO = the Car Computer
Intel Celeron M, [P]SDC, uBlox GPS, GPRS, WLAN, Silabs FM, RDS, TMC,
Dual-audio, Onecable TFT, Microsize: 45 x 108 x 168mm (1.8 x 4.3 x 6.6")
henkbliek is offline   Reply With Quote
prob with mucha shutdown controller geebee Power Supplies 7 12-08-2004 10:30 AM
ATX shutdown controller kit / assembled for sale Mastero Classified Archive 22 01-27-2004 02:33 PM
why use a shutdown controller??? cyjad Newbie 15 12-04-2003 05:49 AM
Cold shutdown controller! phil.45 Power Supplies 2 01-13-2003 10:46 AM
Need help hooking up shutdown controller MAJALO1 Power Supplies 15 10-08-2002 02:27 AM
