Old 01-03-2004, 09:37 AM   #1
adrian_uk17
motherboard connectors
Right i have a M10000 motherboard setup, and i dont want to buy a case to get the power button and led connectors. Basically i want the connectors that connect to where the motherboard on/off and HD LED connectors are, i have tried maplins and didnt get much help.
Does anyone know a UK supplier for these sorts of things?
Any help appreciated
Adrian
adrian_uk17 is offline   Reply With Quote
Old 01-03-2004, 10:06 AM   #2
Blop
Cpc do everything like this...
http://custom1.farnell.com/cpc/
But it is just a standard switch, in testing (all components stripped out on desk) i normally boot a computer by shorting the pins with a screwdriver!! so you could just get any switch and connect it with wires and 'bodge it'.
Blop is offline   Reply With Quote
Old 01-03-2004, 10:24 AM   #3
Blop
or i thought u meant the switches and not the lights!!! the above still applies minust the screwdriver
Old 02-20-2004, 10:01 PM   #4
divinity's Avatar
divinity is on a distinguished road
Yaaay!
You rock! hehe I just got all my parts in for my carputer, but didn't order a case or any switches. I would not have gotten much sleep tonight if I hadn't just shorted the pins with a screwdriver to turn it on.
1997 Honda CR-V
Audio::Custom Speaker Box:/:2x10" Rockford Fosgates:/:Sony Xplod amp
Computer::Epia M10000:/:Deluo GPS:/:Lilliput 7":/:802.11g:/:In a shoebox
Software::FrodoPlayer + Destinator3
divinity is offline   Reply With Quote
Old 02-24-2004, 05:09 PM   #5
dank_Army is on a distinguished road
hi Divinity,
Can you tell me what buttons you ordered to act like an on button and reset button please? as ive been looking for ages to find one and cant see which is the best to buy?
Dank_amy
dank_Army is offline   Reply With Quote
Old 02-24-2004, 05:12 PM   #6
Cherub211's Avatar
Cherub211 is on a distinguished road
any "momentary pushbutton" should work for a power on or reset button
^ that's the term you want to for
Cherub211 is offline   Reply With Quote
Old 02-24-2004, 05:54 PM   #7
divinity's Avatar
Quote: Originally Posted by dank_Army
hi Divinity,
Dank_amy
I found an old power button off of a mac G3 system I no longer was using, and thanks to a bit of shaving with a razor blade it fit the pins on the motherboard. But like cherub said, any momentary switch will work. you don't want a toggle switch that turns the flow on and off, just one that completes the circuit when you push and breaks it when you let off.
1997 Honda CR-V
Old 02-24-2004, 05:59 PM   #8
kami333
I've seen people use doorbells even.
kami333 is offline   Reply With Quote
Old 02-25-2004, 03:45 AM   #9
Raw Wave
Laidback's Avatar
Laidback is on a distinguished road
Making passengers ring a bell before letting them into your car seems a bit petty!
Laidback
Laidback Carputer
Laidback is offline   Reply With Quote
Old 02-25-2004, 10:55 AM   #10
Cherub211's Avatar
You're not making any sense.
Cool new motherboard. LVDS built-in! billthecat General Hardware Discussion 12 05-16-2003 04:30 AM
"Y" Power connectors GRUNT Power Supplies 8 05-04-2003 10:16 PM
Wi-Fi Ehternet PCI Card - Is my motherboard PCI Local BUS 2.1 Compliant? smoldyr General Hardware Discussion 1 11-14-2002 08:56 PM
connectors cvi LCD/Display 0 03-02-2002 07:05 AM
getting an odd motherboard to power on karmann Power Supplies 13 11-28-2001 06:27 PM
