Notices
Old 01-04-2004, 05:21 PM   #16
robiewp's Avatar
ITPS? whatcha smokin? I didn't spend $40+ on a glorified linear regulator (just joshing! don't bite my head off!). As for where I would put one if i had one? I'd plug the power (not switching) part into the tank. Atleast in my experience, except when pretty close to dead, a car battery gives pretty close to 13.8v (including the one in my tank, as i've tested).
Charging? the battery is charging any time the car is turned on. It's basically in parallel with the regular battery any time the key is in the accessory position.
This is working for me. I don't know if it will work for others, but if you have the space for an additional battery, I think this is a better solution than the big capacitor idea. As for how it compares to ricky's design, I have no idea. All i know is its simple.
Use the source, Luke.
car computer rev 3: 8" lilliput and usual suspects
robiewp is offline   Reply With Quote
Old 01-04-2004, 05:33 PM   #17
Raw Wave
robiewp,
Sorry I got alittle confused at first...my brain hurts
I didnt realised you connected the backup battery on the (87) of the relay. Which means your backup is connected to the main only when theres a +12V on the relay?
So your backup only get charged up when the "accessory" is on. The accessory do get cut out when cranking, I dont know if this is the case for all cars. So in turn your backup get disconnected when cranking...It obviously worked for you but I had this fear were the starter motor may have already start draining the battery before it disconnect the second battery. This happen in split second but I kept thinking it may be enough to reboot some setup.
The diode based tank allow the backup to be charged at all time ignition on or off.
Ricky327 is offline   Reply With Quote
Old 01-04-2004, 05:35 PM   #18
mst
mst's Avatar
Maybe I am wrong but I am afraid to send unregulated 13,5 volt to the screen and the motherboard (the PW-70 does not regulate the 12 volt).
About the "big capacitor" idea,i understand that you needs 50 Fa for it to work,that is a little to expensive and too big for me
I like the PW-70,it is not too expensive and small,it fits on the motherboard;but if you have to add battery(with or without relays and diode and capacitors,it gets bigger)
The sproggy is the same price (with the free parts)but it is not small.
The best would be a Opus but they are expensive and big.
mst is offline   Reply With Quote
Old 01-04-2004, 05:43 PM   #19
robiewp's Avatar
Quote: Originally Posted by Ricky327
robiewp,
The diode design sounds cool. My concern would have been if i had substantially discharged my tank, I'd suck the juice required to bring the batteries to equilibrium out of the main battery, and not be able to crank. This obviously isn't a problem with a small battery.
My accessory does indeed cut out while cranking. I had another solution devised before I realized this: quite simply, conect the tank to pin 87a, and 86 to the starter wire. This might eleviate some concerns about the relay not switching quickly enough- the relay for the starter is probably just as slow
One thing i had been considering was some means to only have the tank connected to the main battery when the car is running. The accessory method can't guarentee this. I don't know enough about the ignition harness, but it seems to me, that connecting 86 on the relay to ignition 1 or 2 (and the tank to 87) might accomplish this.... but then you'd need a seccond relay to kill the bridge durring crank.
I might later throw in something to bridge the circuit durring crank if my computer equiptment is hard switched off (by relay)... that way if my main battery is too low to start I could use the tank.
Old 01-04-2004, 05:43 PM   #20
Raw Wave
Sproggy is a good design if it is really true it can survive the crank. The 1F is very expensive and bulky. I dont know if the sproggy has been redesigned or not, but I just looked at a modified sproggy and I beleive it can survive a crank.
Surving a crank solution doesnt have to be that big. On the experiment I just tried im using a 12V 0.8Ah...its probably the smallest lead acid you can buy, its about the size of a big match box. Some even use a full car battery...no where I can put that.
I dont know what robiewp is using but I cant use OPUS, SPROGGY, ITPS or something like that as my setup is based on a laptop motherboard.
Old 01-04-2004, 05:52 PM   #21
Raw Wave
The 0.8Ah Ive used is probably negligible to the car battery
Yes the hardest part is the ensure the backup is fully disconnected before the engine start cranking. And I guess one of the way to achieve this is to have an additional switch that get triggered as you turn the key to crank the engine...before it crank.
It seems easy but theres alot to think about to design a good tank circuit that will work for every setup.
Old 01-04-2004, 05:54 PM   #22
robiewp's Avatar
You're definitely NOT wrong to fear sending unregulated voltage to the screen and motherboard. Not only does the PW-70 not regulate the 12volt line, but under some circumstances it does not properly regulate the 3.3v or 5 when seeing 13.8! To say that I don't use the ITPS is not to say that I send unregulated voltage to the PW-70. I considered it as a possibility, but after some testing found that when 13.8v powered the PW-70, by whatever act of nature and god, the vt6103 chip (lan) was getting voltages outside of its tolerances. This was the only chip I checked, but I would not be suprised if there were more. Even if you're not noticing problems with unregulated current does not mean you arent' slowly killing your computer
I have the fine motor skills of crack fiend so I shy away from soldering intensive stuff, though i can manage most of the time (you do have to build the sproggy, right?)
Old 01-04-2004, 05:55 PM   #23
mst
mst's Avatar
A few months ago I was nearly finished my setup for my "still under renovation" Golf GTI 1983 with a 16v engine with a laptop 266 Mhz, mainly for GPS,then I had the (mis)fortune to read about the Via Epia motherboards on the net and later I found the MP3car forum,it has been quite an expensive meeting,the laptop is dished,so is the car radio and it will take quiet a few months before the car is finished;but the carputer can do a lot more then an old laptop
Old 01-04-2004, 05:58 PM   #24
mst
mst's Avatar
Oh,I can solder it OK,but if it works after,that is the question
Old 01-04-2004, 06:04 PM   #25
robiewp's Avatar
I couldn't agree with you more. It's entirely a case by case basis thing with the type of design I was speaking of, and couldn't be readily generalized to, "put the + here and the - here". In my mind it's more advantageious, but then again all of my needs were in mind
I've been almost done for 6 months! Really though, I'm almost done!
Old 01-04-2004, 06:12 PM   #26
mst
mst's Avatar
Well If you continue to read this forum it might take more time,it is fantastic so many good ideas you can find to put in your car
Old 01-05-2004, 01:33 PM   #27
numberone's Avatar
Quote:
Even with this improved setup I dont think its good enough for ITPS. The only way around the ITPS is to add a relay that short out the diode so no voltage is ever lost. Even with that zero voltage drop circuit, the ITPS minimum operating voltage of 13.3V is still pushing it to the limit.
As I can see your tank circuit doesn't provide any regulation. Could you suggest any itps free solution based on your circuit? I'm starting to hate my ITPS. IT SUCKS!
http://www.m2visio.de
|CAR ENTERTAINMENT SYSTEM
|Epia m10000 w. 256mb
|20gb 2.5,slimDVD
|Morex Cubid 3688+ITPS
|Lilliput VGA+Touchscreen
numberone is offline   Reply With Quote
Old 01-05-2004, 01:45 PM   #28
robiewp's Avatar
regulation is too complicated for our simple minds
Old 01-05-2004, 01:58 PM   #29
Raw Wave
I guess you just want a regulated +12V for your PC? True the ITPS simply cant do this without the input being above +13.3V
Well the main problem is desiging a circuit that can supply +12V @ 5A or more with an operating voltage from 8-16V lets say. 8-16V supply range should survive a crank. It is possible and have been done before, I havnt looked deeply into it as I dont need one
Subtituting the LM1084 used in ITPS with a lower voltage drop regulator should help. But even then a zero voltage drop tank with a zero voltage drop linear regulator Ill say it can still be unreliable. The car voltage is just not high enough and tend to varies from 11.5V to 13.8V in normal operation. With a perfect setup 11.5V can still crash your PC.
As been mentioned in some thread before, the voltage can be stepped up by using a DC-DC laptop adaptor. This stepped up voltage of 14-15V is then fed into the ITPS. Of course the DC-DC adaptor must be able to work down to 8V...most only work down to 11V. There are some talk about a step up regulator that outputs 12V...I dont know if it does work well.
It is a very messy idea...check this out, I think its cool :
http://www.mp3car.com/vbulletin/show...097#post149097
or just use something else like the OPUS.
Sorry no direct solutions
Old 01-06-2004, 03:00 AM   #30
mst
mst's Avatar
Hi
I looked at the schematic of the sproggy,as fare as I can see its takes the incoming voltage lowers it to 5 and 3,3 volt regulated and then takes some of the 5 v and raises it to 12 volt,this time regulated.I hope even if it gets only 8 volt it can still make the 5 volt.
Only problem is to get the max787's free,Farnell sells them for $18 plus 19% sales tax plus $7 transport (if they have them in stock),Well one day Maxim must catch up with there back orders.
MPJA - MECI ASTEC DC-DC Converter Luc General Hardware Discussion 39 11-22-2004 10:31 PM
Tank Circuit Voltages ciagon Power Supplies 3 11-23-2003 04:45 PM
Newbie has a question about Tank Circuit. GScherler Power Supplies 1 11-14-2003 05:15 PM
tank circuit TiTUS General Hardware Discussion 10 09-07-2003 06:05 PM
tank circuit - what output do I need? maxcosity Power Supplies 16 06-03-2003 05:00 PM
