The MP3car.com Store
Thread Tools Display Modes
Old 02-18-2004, 12:51 AM   #61
LESLIEx317537's Avatar
Vehicle: STi
My Photos: (0)
I'm going to use a LM317 after the diodes to bring back up the voltage to what the ITPS likes.
SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
GPSing - Digital Speedo
Relocating headunit and extending faceplate
Button app to Alt-Tab between two programs
LESLIEx317537 is offline   Reply With Quote
Sponsored Links
Old 02-18-2004, 01:08 AM   #62
none's Avatar
My Photos: (0)
The LM317 is a linear regulator, it will only lower voltage, not raise it.
none is offline   Reply With Quote
Old 02-18-2004, 01:26 AM   #63
Vehicle: STi
My Photos: (0)
OOps, then how about a 7815 to bring voltage up to 15 volts? Then mess with that?
Old 02-18-2004, 01:31 AM   #64
none's Avatar
My Photos: (0)
Same deal. Needs something like 17.5 volts in to put out 15 volts.
Old 02-18-2004, 03:14 AM   #65
phc
phc's Avatar
Vehicle: 2004 WRX Wagon
My Photos: (0)
Did you mean you don't need to limit the voltage?
Well, you do, but your car's alternator should have a ~13-14V regulator built in. 15V for a Hawker 12V battery is the max. Hawkers dont need any current limiting either, most sealed lead acids do. This can be done with a properly sized resistor.
To understand ni-cd charging - do some searches and read http://www.vencon.com/articles/nicd2.html
If you want to charge at a rate of 4C, then you need a very good "peak detection" charger - one that detects the battery is charged and shuts off.
Once a battery is fully charged, if you continue to charge, the battery produces gas creating a high internal pressure, and a sudden rise in temperature. High temperature kills batteries.
Typically NiCd are charged at a constant current, say 3C for good cells that we use in Battlebots. I have a 2.4amp-hr pack that I charge at 7.2 amps. To charge at a constant current, the charger needs to vary the voltage. It also monitors the voltage for its peak, and then needs to shut off or go into trickle charge 10% of C or in my case 0.24 amps.
I would never hook up a nicd battery to an automotive system. I use Astroflight 112 chargers
http://www.astroflight.com/e/env/000...roducts:af-112
www.mechatroniks.com - Bots
www.mechatroniks.com/wrx - Car PC Project
-=Now offering a Lilliput Bezel for WRX=-
**Sept 2005 - website moved to mechatroniks.com**
phc is offline   Reply With Quote
Old 02-18-2004, 09:39 AM   #66
MySQL Error
MatrixPC's CarPC Specs
MatrixPC's Avatar
Vehicle: 89 Supra Turbo, 04 Toyota Matrix XR
My Photos: (0)
This is the best method and you don't need tank circuit of any kind.
Buy a stick shift/manual car.
When park, park up or down hill.
When ready to go, release e-brake, push clutch, engage gear. When the car roll fast enough, release/pop clutch, car start. ZERO voltage drop solution. hahahaha.
You never need to use the car starter
BTW going thru this thread, it look very messy and a big install. Why not go with Opus or Sproggy? Those don't cost that much more and they survice cranking. And most important is you don't have to worry about a having a bomb in the cabin (slave battery).
AS for Sproggy 3.0 design, the 12V @2A out is regulated by boost method from 5V rail. 3.5 using the same method but output on 12V line is 5A. If you have some or little electrical knowledge, Sproggy PSU is a very good learning tool and it works.
I am not sure about the issue between Sproggy and Via M mobo but it work well with standard ATX mobo.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 02-18-2004, 10:52 AM   #67
Vehicle: STi
My Photos: (0)
Yes, I'm going with a SLA battery. I know about charging slightly since I fly RC PLanes, Astroflight are good chargers, I use a Great Planes Triton for my Ni-Cd's, Ni-MH, and Lithium Polymers (ETECS, Kokams).
Just thinking of a good way to hook everything up. Seeing everything, I definetly need the diodes and resistors if I use a SLA other than the Hawker. What's the price of the Hawker 12 volt and where is the best place to buy online?
Old 02-18-2004, 10:58 AM   #68
none's Avatar
My Photos: (0)
Agreed 100%.
Old 02-18-2004, 11:04 AM   #69
Vehicle: STi
My Photos: (0)
Cause my Keypower puts out 250watts and rocks.
I am gonna buy a Opus soon too. I'll have two nice PC PS for the car.
But for 25 buks or so, I wanna make my carpc not reboot when I get gas in my car since my 300HP AWD car eats so much gas, I have to always stop at the gas station and then kill my engine, no hills on my gas station so I can't pop the clutch.
So the Opus is guaranteed to survive a crank? Will it run a P4 board? I plan on changing my 1Ghz P3 to a P4 soon in summer.
Not only to have the most powerful 4 banger in North America, but also the fastest P4 in the car in North America. Besides, making your own stuff is fun. Sometimes I don't feel like buying premaid stuff. I'ma do it myself kind of person. I change my own oil, why not go to Jiffy lube, You goto Jiffy lube or your dealer, I'll do it myself. It's part of the fun part, building and learning and posting questions on this forum
Old 02-18-2004, 11:14 AM   #70
none's Avatar
My Photos: (0)
Sproggy! (Mastero mk3.5.)
Sponsored Links
Old 02-18-2004, 11:35 AM   #71
Vehicle: STi
My Photos: (0)
I've always seen the sproggy and how it's been changing.
It's up to version 3.5 now? How many watts is it? And how hard is it to aquire all the parts. Does he sell a kit? Is it in a box allready?
Old 02-18-2004, 12:15 PM   #72
MySQL Error
MatrixPC's Avatar
My Photos: (0)
You can buy a Sproggy MK3.5 as a kit or just a PCB. With a kit you still need to buy the main Maxxim or Linear Technology and National Semi (for 12V) chips.
Oh, changing car oil isn't that hard. For the past 15yrs I only brought my car to dealer for changing oil 5 times because they offer free car wash with any service.
I can change the oil in my Matrix within 15 min but about an hr on the Supra because the oil filter location on the Supra is freaking hard to reach. It stuck between the side of engine block and the Turbo charger.
Old 02-18-2004, 02:17 PM   #73
Registered User
Mastero's Avatar
My Photos: (0)
www.mastero.tk
All your answers are here ! it changes for the good.
Mastero
mastero76@hotmail.com
NEW LINK TO MY SITE ]{*}CYBER SHOP ONLINE{*}
AIRCON UNIT VER 2 IS NOW FOR SALE ]
Life is short enjoy it before it ends.
Mastero is offline   Reply With Quote
Old 02-18-2004, 06:43 PM   #74
Vehicle: STi
My Photos: (0)
OK, so what's the best power supply out there?
This is what I have been running for 2 years with Jeff's shutdown controller. It says min in is 9 volts, so why does my PC reboot on crank?
http://www.keypower.com/proddetail.a...&linenumber=15
Old 02-18-2004, 07:08 PM   #75
Vehicle: STi
My Photos: (0)
In regard to the original post:
Quote: Originally Posted by Ricky327
Alot of poeple here seems to have problem fully charging the tank battery. The standard tank circuit uses a diode typically the MBR6045. Because of the voltage drop of the diode, the charging voltage is always 0.6-0.7V lower than it should be...13.8V. With this standard setup the backup battery never get fully charge and may not function properly during crank.
On the diagram I have added a limiting resistor and an extra diode. The limiting resistor is directly connected to the main battery, this ensure that the backup battery get the full voltage from the main battery.
Won't the resistor drop the voltage going into the backup battery also?
The maximum current can be drain with this circuit is only 3A as limited by the diode. I dont have a more powerful diode to test it out A bigger backup battery can also be used together with a recalculated limiting resistor value and suitable wattage.
Ill use a higher rating diode next time on a bigger PC...If anyone wanna try first please do so and report back
You can run diodes in parrallel to acheive more amp loading.
Sponsored Links
vB code is On
Trackbacks are Off
MPJA - MECI ASTEC DC-DC Converter Luc General Hardware Discussion 39 11-22-2004 09:31 PM
Tank Circuit Voltages ciagon Power Supplies 3 11-23-2003 03:45 PM
Newbie has a question about Tank Circuit. GScherler Power Supplies 1 11-14-2003 04:15 PM
tank circuit TiTUS General Hardware Discussion 10 09-07-2003 05:05 PM
tank circuit - what output do I need? maxcosity Power Supplies 16 06-03-2003 04:00 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
