Old 04-02-2004, 09:23 AM   #91
seems to simple
It seems the simplest solution to the whole tank circuit idea would be hooking up the computer to a second battery. Then running the first and second battery in parallel with a relay placed in between on the positive line, the relay being closed when it is recieving power via the ignition line.
This benefits you by no voltage drop during cranking, the battery will always be charging when the car is running, and you can run the computer with the car off and no fear of killing the main battery
david_594 is offline   Reply With Quote
Old 04-02-2004, 09:32 AM   #92
LESLIEx317537's Avatar
I say run the relay off the 12 volt PC power supply molex so the batt will only charge and be tied intot he circuit when the PC is on.
-This eliminates potential hazards of using a Ni-Cd in the car.
-It's been tested and works.
-8 Diodes is alot. How many PC's you running? lol
My Setup survives cranks and I don't even have anything except for my stereo amp 1 farad cap. Woo hoo. I run everything off my PC PS, screen etc... and it's the 250watt Keypower.
SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
GPSing - Digital Speedo
Relocating headunit and extending faceplate
Button app to Alt-Tab between two programs
LESLIEx317537 is offline   Reply With Quote
Old 04-02-2004, 09:34 AM   #93
I use a radio shack DC to AC inverter and a 50 bucks UPS, never had a problem
1938 Chevrolet Master Deluxe
My Car My CarPC
Alessio is offline   Reply With Quote
Old 04-02-2004, 09:37 AM   #94
I was thinking more along the lines of an automotive battery, or mabey something off of a motorcycle.
Old 04-02-2004, 09:45 AM   #95
Yeah a SLA battery.
DC-AC inverters take up more space.
DC--->AC--->DC why?
Old 04-02-2004, 12:00 PM   #96
Yeah a SLA battery.
DC--->AC--->DC why?
One word : easy
I got a truck, so an UPS and an inverter under the seat is nothing
did I say easy?
My Car My CarPC
Old 04-02-2004, 12:05 PM   #97
zvi
zvi's Avatar
I have motorcycle one, its 12v 9Ah, I'll post pictures of my battery tank setup on monday
'93 Opel Vectra A with Custom Dash with 7" lilliput
VoomPC/M1-ATX/M10K/256 RAM/20GB 2,5' HDD/Gemtek USB Radio/WinLite/RoadRunner
http://zvi.home.ge/pics/?dir=vextra
zvi is offline   Reply With Quote
Old 04-02-2004, 12:10 PM   #98
Raw Wave
Isnt that because you are using a keypower PSU? I maybe wrong but isnt supposed to survive a crank anyway?
Ricky327 is offline   Reply With Quote
Old 04-02-2004, 12:26 PM   #99
no, only after i added the 1 farad cap.
Opus, can survive stock.
Old 04-02-2004, 12:31 PM   #100
no1knows's Avatar
i love barnsley
Mods: 18" Boss rims,Twin custom stainless exhaust,cold air induction.
Sound: Pioneer 7400 HU & 6x9's,12" Vibe Sub,600W Kenwood amp.
CarPC: MicroATX, Inverter, WinTV, Lilliput 7", USB GPS
http://www.no1knows.com/galleries/
no1knows is offline   Reply With Quote
Old 04-02-2004, 12:36 PM   #101
Usually DC - AC-DC will introduce line noise and other unwanted noises.
Old 04-03-2004, 12:42 AM   #102
zvi
zvi's Avatar
here is my small Accu:
http://zvi.home.ge/pics/vextra/accu.jpg
Old 04-03-2004, 07:46 AM   #103
zvi,
A 9Ah is way overkill, all you need is 1Ah if anything.
Also, assuming you have a Z, you probably take turns like I do, and I autocross. So a 9Ah battery placed in the car is just not ideal...
How do you have it wired up and mounted?
Old 04-03-2004, 11:00 AM   #104
zvi
zvi's Avatar
zvi,
Yes, I know, whole my system will use a bit of it, but this accu was easiest to find here (and cheapest), so let it be
Well I dont autocross, only if I am in hurry to somewhere , it's just a peaceful, family car
I have wired it up as Ricky327 proposed in his first post, just only I have four of 1N5822 diodes (in place of one, total - 8) in paralel. I have 120watt PSU, so I assumed, that current coming from accu might be 10 amps, so I put four of 3 amp diodes, total can pass 12, besides: these diodes drop less voltage on less amps, so 4 of them drop less volts. Now, with no load, it drops 0.25v only
I have 12.35 with engine off, and 12.10v when cranking.
I have used 15 ohm Resistor, impedance I calculated also from Ricky's first post: 9ah Accu needs 0.9 amp for charging -> I have 14v with engine on-> as V=I*R -> R=14/0.9=15.5 ohm, so I found 15 ohm resistor.
The backup baterry just fits next to my main baterry
let me draw a circuit and pcb I have used...
Old 04-04-2004, 05:32 AM   #105
zvi
zvi's Avatar
the green colored is a copper on the back side of the PCB
MPJA - MECI ASTEC DC-DC Converter Luc General Hardware Discussion 39 11-22-2004 09:31 PM
Tank Circuit Voltages ciagon Power Supplies 3 11-23-2003 03:45 PM
Newbie has a question about Tank Circuit. GScherler Power Supplies 1 11-14-2003 04:15 PM
tank circuit TiTUS General Hardware Discussion 10 09-07-2003 05:05 PM
tank circuit - what output do I need? maxcosity Power Supplies 16 06-03-2003 04:00 PM
