Notices
Old 01-07-2004, 06:27 PM   #1
What size fuse should I use on distribution block going to Opus power supply?
I have 4 AWG wire running to a dristribution block in my trunk. That splits into two amps and my carputer. What size fuse should I put on the line running to the Opus in my carputer? In other words, how many amps does the Opus draw?
smoldyr is offline   Reply With Quote
Old 01-07-2004, 07:05 PM   #2
Mr. Wiggles
shakes's Avatar
take the wattage of your opus ... divide by 12, and that's the max current it will draw. add a few amps to that and there's your fuse size.
My JeepPC Install
"there are no stupid questions, just stupid people."
"it's been agreed the whole world stinks so no one's taking showers anymore"
shakes is offline   Reply With Quote
Old 01-07-2004, 07:08 PM   #3
isnt the max wattage of the psu the max sustained wattage? you might want to add more than just a few amps, for burst power.
edit:
also, the psu only claims it's 90% efficient. that's cause it has to go dc-ac-dc. (transformers only work on ac power). so you have to have at the least 110(about) percent of it's wattage before dividing by 12 (if you want to follow his example). but i still think the wattage applies to sustained flow ("rms", if we were talking about amps.) so allow some burst power. yeah, that's what i was saying. you need to allow for burst power.
Walleye is offline   Reply With Quote
Old 01-07-2004, 07:23 PM   #4
I found a 20 amp fuse, that good enough? It's a 150 watt Opus by the way.
Old 01-07-2004, 08:05 PM   #5
Mr. Wiggles
shakes's Avatar
that should be fine
My JeepPC Install
Old 01-08-2004, 12:38 AM   #6
to my knowledge it's a 20 amp fuse that goes to the radio anyway.
WTB: 13.8VDC@10A power supply for Opus GScherler Classified Archive 2 12-12-2003 03:21 PM
OPUS power supply xenonflx Newbie 1 11-30-2003 06:06 PM
Is there any sk41g shuttle users using OPUS 150w dc to dc power supply inniss777 Power Supplies 8 11-04-2003 12:03 PM
Opus power supply issue dmazyn Power Supplies 2 10-15-2003 07:32 PM
More info on OPUS automotive ATX power supply InvisiBill Power Supplies 3 08-16-2002 03:19 PM
