Notices
Old 01-08-2004, 05:20 PM   #1
A very cheap way to power your PC
A UPS "backup power station" takes 120 volts AC, converts it to 12 volts DC (on some models), stores the power in a battery or two, and then converts it back into 120 volts AC.
One thought would be to only use the 12 volt to 120 volt inverter as a VERY cheap way to power your standard power supply (You can pick up used UPS' for very cheap).
I am aware of the whole noise factor, but if you get a good quality UPS, I am not sure that would be an issue.
If anyone has tried this, let me know, I am interested to see if it would work or not. Thanks
clint_jasper is offline   Reply With Quote
Old 01-08-2004, 05:35 PM   #2
I don't know about just using part of the ups but I seem to recall a thread where some people tested a ups hooked up to an inverter and found it didn't work properly.
grahamrb is offline   Reply With Quote
Old 01-08-2004, 05:42 PM   #3
Well not only that, but do the math... a good UPS is going to cost you at least $100 bucks, then you add in another $30-$50 dollars for an inverter.... now you have enough cash to buy an opus, because your not going to find a "Good" UPS for much less than a $100 bucks w/ a good battery. Its a good idea, I haven't searched for any threads related to it, but its just not economical in the long run!!!
New CarPC on the way again I think. I miss my old one!!!
R3l0ad is offline   Reply With Quote
Old 01-08-2004, 09:12 PM   #4
robiewp's Avatar
it's been discussed a couple of times on this site, and I'll say what I always say: it's nice if you have a UPS laying arround gathering dust, or if you can pick one up from a pawn that doesn't know it to be anything more than a powerstrip, then sure it might be 'cost effective', but they're not designed (unless they're really expensive and are a "true UPS") to run for long (thus heat problems), and for the most part will infact not be cost effective. A good power inverter capable of satisfying your every need (car computer, that is) can be gotten for in the neighborhood of $25
punt
Use the source, Luke.
car computer rev 3: 8" lilliput and usual suspects
robiewp is offline   Reply With Quote
Old 01-08-2004, 09:39 PM   #5
Anyone in So Oregon want a 500 pound UPS system? Runs on 4 12v batteries. Built like a tank. My friend picked it up after his office closed down. It wouldnt way a car down "too" much
e_fractal is offline   Reply With Quote
Old 01-08-2004, 10:31 PM   #6
I guess my brain fart stunk.... oh well, back to the drawing board.
Old 01-08-2004, 11:40 PM   #7
robiewp's Avatar
already got one... but wouldn't mind another one.... If you take out the batteries it doesn't way much... I'll pay for shipping !!
Compaq handheld pc power supply rjstephens Power Supplies 4 05-23-2003 09:26 AM
Cheap low-power ATX DC-DC power supply Telek Power Supplies 169 01-16-2003 02:12 PM
PC power button problem BMp3W Power Supplies 4 10-12-2002 03:36 AM
Have to switch inverter off and on to power up pc mbowler General Hardware Discussion 10 08-22-2000 12:00 AM
remote turn on lead from headunit to power up PC BluCivic93 General Hardware Discussion 3 07-27-2000 03:13 PM
