The MP3car.com Store
Thread Tools Display Modes
Old 01-08-2004, 04:55 PM   #1
MikeH's Avatar
Vehicle: 2007 Acura RDX
My Photos: (0)
Lilliput +12v PSU...how can it work?
OK gearheads....
After pulling apart the Lilliput 12V DC-DC supply, we find that it uses an LM2596-12 switching regulator inside. However, if you look at the graph of the dropout voltage (below), it shows approx .9v required from input to output. This (to me) means that the input must be at least 12.9v for the output to be at 12v. Has anyone with a weak battery experienced the Lilliput going blank when the engine is off? Am I reading this wrong?
MikeH
CarNetix
Helpful info at http://www.carnetix.com
C134, M10000, 40GHDD, XM-PCR, CarNetix P2140, FP
MikeH is offline   Reply With Quote
Sponsored Links
Old 01-09-2004, 12:30 AM   #2
My Photos: (0)
I bench tested the Lilliput cigarette lighter adapter and found out that the dropout voltage is more like 1.7V (12.5V in, 10.8V out). The Lilliput works fine at 10.8V - only thing is the brightness of the backlight is visibly reduced.
shchua is offline   Reply With Quote
Old 01-09-2004, 09:31 AM   #3
MikeH's Avatar
My Photos: (0)
Schua...did you measure the current draw?
MikeH
CarNetix
Sponsored Links
vB code is On
Trackbacks are Off
Frequently Asked Questions bgoodman The FAQ Emporium 33 05-03-2005 06:25 PM
Morex Cubid PSU Protection Circuit? (Would this work better?) chiark Power Supplies 8 06-12-2003 03:58 AM
What to look for in a PSU some info for you cproaudio Power Supplies 9 04-04-2003 01:07 AM
PSU 12V issue Shades Power Supplies 2 05-23-2002 02:59 AM
Small MBD, 12V ATX PSU + More gguy Classified Archive 0 07-16-2001 10:55 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
