Notices
Old 01-15-2004, 02:57 PM   #1
Can the PW-70A support this setup?
Hello All,
Well here is an update in my project so far I have completed my custom
clear case and have my VIA M10000 installed with a Dlink wireless PCI card
and a western digital IDE standard drive and 256 PC2100 DDR. Can this power supply support the gear above I'll also add an ITPS for regulation.
-Eric
erains is offline   Reply With Quote
Old 01-15-2004, 03:46 PM   #2
Super Moderator
hijinks21's Avatar
yes it can probably handle that setup
'98 Explorer Sport
80% done
hijinks21 is offline   Reply With Quote
Old 01-15-2004, 03:49 PM   #3
Mr. Wiggles
shakes's Avatar
the PW-70a will just fine ...
the ITPS is where you need to be careful. it maxes at 60W (5 amps) ...
i can't count how many times this same question has been asked with the same setup and the same PS/ITPS (public school education here)... do some reading in the power supply forum.
My JeepPC Install
"there are no stupid questions, just stupid people."
"it's been agreed the whole world stinks so no one's taking showers anymore"
shakes is offline   Reply With Quote
Old 01-15-2004, 04:46 PM   #4
Hey Shakes,
Yeah I did some searching and it was still unclear to me. I see so the weak link to this setup is the ITPS. I like the setup because of the size and the lower heat output also it is slightly cheaper than the opus. I have one other question. I see allot of folks go the inverter route the main disadvantage I see is size and heat other than that issue will this setup degrade the battery faster than the PW-70a with ITPS?
Thanks for your time
-Eric
Old 01-15-2004, 04:54 PM   #5
Mr. Wiggles
shakes's Avatar
inverters are clunky ... give off more heat ... and very inefficient. they also are likely to give you dirty power unless you get a relly good one ... and then you're spending $100+ anyway.
beside ... inverters convert DC to AC ... then your PC will turn right around and go back from AC to DC. so why mess with all the conversion?
the opus is a better solution than the ITPS/PW-70a ... but more expensive.
if you go the ITPS/PW-70a route you should seriously consider using a laptop hard drive. you'll run into other issues with a desktop hard drive like not being able to power the PC with the car off.
My JeepPC Install
Can the OPUS 150 W support this setup? kiztope Power Supplies 1 01-14-2004 11:45 AM
My planned setup. Please post opinions. audrenaline Newbie 18 12-05-2003 03:56 PM
Who wants Playlist support? ose-ml320 MediaCar 13 11-11-2003 06:43 PM
When will ME support plug-in??? vbi ME Archive 7 10-31-2003 07:39 AM
new setup pics freestyler General MP3Car Discussion 3 06-06-2002 01:08 AM
