The MP3car.com Store
Thread Tools Search this Thread Display Modes
Old 01-16-2004, 02:05 AM   #1
My Photos: (4)
Inverter noise!!
Hey guys I have a jensen inverter which is like 300watt continuous and 600 watt peak. I am running my PS2 off of it and I am getting ALOT of engine noise. I get like a really really high pitched squeal almost when I at high RPMs. I have tried to put a ground loop isolator on the RCAs and that didn't help. I also am getting noise in the picture. Would a small cap on the 12v line help this? Thanks!
williamn333 is offline   Reply With Quote
Sponsored Links
Old 01-16-2004, 03:06 AM   #2
Raw Wave
Confused's Avatar
Vehicle: Honda Prelude 2.2 VTEC / Ford Anglia 105E
My Photos: (0)
I fixed 95% of my audio problems by grounding the power supply (or a metal part of the computer) to the same ground point as my inverter/amps
Garry
Co-Developer of A.I.M.E.E
www.aimee.cc
Confused is offline   Reply With Quote
Old 01-16-2004, 06:52 AM   #3
MikeH's Avatar
Vehicle: 2007 Acura RDX
My Photos: (0)
William....I did the same as confused (gounded my carpc case), but also lifted the 3rd pin (ground) on my 3-prong AC power plug that feeds the AC/DC brick that feeds my carpc. Most inverter noise disappeared.
MikeH
CarNetix
Helpful info at http://www.carnetix.com
C134, M10000, 40GHDD, XM-PCR, CarNetix P2140, FP
MikeH is offline   Reply With Quote
Old 01-16-2004, 08:27 AM   #4
Raw Wave
Defiler's CarPC Specs
Defiler's Avatar
Vehicle: '05 Shadow Mica Matrix XR
My Photos: (1)
Just asking not bashing...Isn't the 3rd (ground) pin there for a reason? I thought it isn't good to do that. Am I wrong on thinking this?
/////Alpine PXA-H700
/////Alpine MRV-F345
Aura MR62 (F and R)
Sansa Clip
All wires by Knukonceptz.
My Current MP3s
IamDefiler.com
Still have tons of parts for sale!!! MB's, CPUs, Fans, etc. PM me and I will send a list.
Defiler is offline   Reply With Quote
Old 01-16-2004, 08:49 AM   #5
MySQL Error
MatrixPC's CarPC Specs
MatrixPC's Avatar
Vehicle: 89 Supra Turbo, 04 Toyota Matrix XR
My Photos: (0)
Try NOT to run power and RCA cables together. If you run the Power cable on one side of the car, the RCA cable should be on the other side of the car. A big power cable (10GA at least, 8GA or 4GA is better) will help. A ground cable should be the same size or bigger than the power cable and as short as possible also help.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 01-16-2004, 12:08 PM   #6
My Photos: (4)
I don't have a PC in the truck yet. It is just an inverter with a satellite box and a PS2. It mainly does the noise on the PS2. Let me know what you guys think!
Old 01-16-2004, 12:37 PM   #7
Vehicle: 1997 Honda Civic LX
My Photos: (0)
Try getting a surge protector like a single port surge protector from your inverter to your PS/2. Make sure its a good one, don't skimp out on it!!! There is a link somewhere in the forums for one at radioshack.
New CarPC on the way again I think. I miss my old one!!!
R3l0ad is offline   Reply With Quote
Old 01-16-2004, 12:38 PM   #8
Raw Wave
Confused's Avatar
My Photos: (0)
Put a wire from a metal part of the casing of the PS2 to the same ground point.
Garry
www.aimee.cc
Old 01-16-2004, 12:48 PM   #9
Raw Wave
Defiler's Avatar
My Photos: (1)
HA. I've been promoting that like they're goin' out of style. I totaly forgot about these for some reason. It took 99% of the noise out of my setup.. here is the link to the better quality one: http://www.radioshack.com/product.as...5Fid=61%2D2420
Aura MR62 (F and R)
Sansa Clip
My Current MP3s
IamDefiler.com
Old 01-16-2004, 01:42 PM   #10
MikeH's Avatar
My Photos: (0)
Defiler
Excellent question. I'm not an expert in this area, but here's my theory (I'm ready to be corrected if we have experts in the group)...
The 3rd prong is used in electrical power systems to provide a common case shield between devices that use the same AC circuit. This is supposed to prevent a lethal voltage from building up between the "touchable" parts of the devices (ie the cases), since the AC common (return) wire is typically not connected to the case. In the carpc environment the AC is generated locally at the inverter and passed thru a transformer which isolates the AC from the case. Therefore, the inverter case ground COULD be removed from the AC part of the system (by lifting the 3rd prong on a 3wire-2wire AC adapter plug), and tied to the DC part of the system thru a common ground wire. OR, as in my case, left floating, since this produced the least "noise" in my audio system.
Again, proceed at your own risk. This worked for me, with my el-cheapo WalMart inverter. Your results may vary.....but I'd love to hear how it works for anyone who tries it.
MikeH
CarNetix
Sponsored Links
Old 01-16-2004, 05:07 PM   #11
My Photos: (4)
Defiler,
Did it take the video noise out of the picture? I notice I am getting some wavy lines and stuff from the inverter. BTW, thanks alot for that surge protector idea r3l0ad and defiler!!!!
Old 01-16-2004, 10:25 PM   #12
Raw Wave
Defiler's Avatar
My Photos: (1)
Never had Video noise before...How are you powering it? From your PSU or car +12?
Aura MR62 (F and R)
Sansa Clip
My Current MP3s
IamDefiler.com
Old 01-16-2004, 10:52 PM   #13
My Photos: (4)
I am powering the inverter from my 12v battery.
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
relay, inverter, fuse problems cheesyhoward General Hardware Discussion 6 06-22-2004 03:05 PM
inverter noise. EvilInside944 Power Supplies 5 07-17-2002 08:03 PM
Power noise - the horror!!! mtmsol Power Supplies 3 06-19-2001 09:13 PM
Possible to shield RF noise from inverter? Jodoveepn Power Supplies 7 04-26-2001 06:07 PM
odd inverter behavior jshrieve General Hardware Discussion 30 04-10-2001 04:53 AM
Sponsored Links
Ad Management by RedTyger
