01-16-2004, 11:04 PM
#1
TI Laptop PSU Chip
It was over a year ago but somebody posted about a surface mount chip from TI (Texas Instruments) that was basically a Laptop PSU chip..... It took Battery voltage input (12VDC I think) and produced 3.3VDC, 5 VDC, 12VDC, etc... basically all that was required for an ATX PSU....
Now it was insufficent amperage for what a Car computer needed, and it also required supporting circuitry.... but it appeared to be a great starting point...
I thought so much of it at the time that I got samples from TI.. ones that I can't find now... crap...
But I have two question... does anybody know what chip I am talking about? also assuming it gives what we need, but with insufficent amperage, why not run several in series to up the amperage????
Any ideas?
01-17-2004, 05:39 AM
#2
Raw Wave
Was it the TI ISR series? I use a TI PT5071 and a PT6625 to power my system.
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 8Gb flash DOM, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
01-19-2004, 08:07 AM
#3
No, that doesn't look like what was mentioned before, but WOW, is that by chance your entire power supply?
I will check out those two chips you mention.
01-19-2004, 08:13 AM
#4
Raw Wave
Yep, that is my entire power supply (including remote on - no relay needed). It's low power by most people's standards (5V @ 5A, 12V @ 1.5A), but is very efficient and small in size (which is good, since my entire carputer is small).
Rob
01-19-2004, 01:02 PM
#5
That is cool Rob,
I looked through the specs on those chips.... pretty nice, but as you said they are low amperage....
I looked through the TI site and also Maxim and can't find a similar chip that would have
Vin(min) = 8 VDC
Vin(max) = 15 VDC
Vout = 12 VDC (+/- 5%)
Iout = 5 A max
Has anybody seen such an animal. There is some 5 VDC out chips that give 5 A, but no 12 VDC out that I have found.
01-19-2004, 04:00 PM
#6
01-19-2004, 10:20 PM
#7
Thanks for the suggestion VW, but I am a little confused on the LM3478. First off the Web Design on the National site doesn't seem to function right for the given inputs...
Vin(min) = 8 VDC
Vin(max) = 16 VDC
Vout = 12VDC
Iout = 5 amps
I put that in at first and it says "use the LM3478", so when I got to "do the desgin, it comes back and says nothing meets my requirements, please use LM3478....
Running in circles... I read the entire data sheet on the LM3478 and I all I see is 5VDC at 5amps and then later 12VDC at 1.2 amps..... Can the LM3478 put out 12VDC at 5 amps????
Sorry to be a pain in the ***, but this circle is getting boring...
Also what about the LM2587? I kind of get them impression that will top out at 1.2 amps also....
But thanks for the help.... it is much appreciated.
01-22-2004, 02:29 PM
#8
Bump
| Thread Tools |
| Display Modes |
Linear Mode
