Notices
Old 01-21-2004, 12:21 PM   #1
XxAndyxX's Avatar
Hooking OPUS to IGN wire?!?
I was planning on just tapping my opus ignition wire into my amps remote start wire. But is the remote start wire on my amp connected to my radio? Because I'm taking out my existing head unit and replacing it with an LCD so I'm hoping I won't have to remote the remote start wire along with it...
XxAndyxX is offline   Reply With Quote
Old 01-21-2004, 12:48 PM   #2
bjm2020's Avatar
In most car stereo setups the remote wire of the amps are ran to the remote wire in the head unit. You can run it to some kind of switch though. When I remove my head unit I plan to run the remote wires into one of those shifter knobs with the switches on it.
EPIA 800, DWW-7VGA LCD w/Touchscreen, 256mb ram, dvd rom, ati radeon 7000 video card, 80 gb 3.5" hard drive.
bjm2020 is offline   Reply With Quote
Old 01-21-2004, 03:03 PM   #3
00CericaRuss's Avatar
i run my remote turn on off one of the 12v drive wires from teh opus
Car: 2000 Toyota Celica GT-S
Mods: Yep
Carputer: VIA M9000 | Opus 150 | 512MB PC2100 | 60GB Notebook HD | Slim/Slot DVD/CDRW | Audigy2NX | Xenarc 700TSV | (2) DSCustoms DS700HRS (in trunk) | SMC USB 802.11b | CoPilot | DLink FM tuner | Cliffnet
00CericaRuss is offline   Reply With Quote
Old 01-21-2004, 04:20 PM   #4
leenas's Avatar
What can you do is use an automotive relay that is tapped into something like your clock or something that is only on when your car is on.
Use the tapped clock wire as the switch for the relay and get your 12v line from the wire that would have powered your head unit. Then run the output from the relay to the ignition wire of the opus. This way your carputer will be on only when your clock is on which i assume is only when your car is on.
For using the ignition wire just make sure that the ouput on that is 12v. Also im not completely sure how the ignition wire works but i assume its sending a constant 12v which is all you need for the relay switch. Some easy testing can be done with a multimeter to make sure everything will work.
leenas is offline   Reply With Quote
Old 01-21-2004, 04:21 PM   #5
XxAndyxX's Avatar
Then what do you have the IGN wire for the OPUS connected to?
Old 01-21-2004, 07:21 PM   #6
+12v accessories line that went to my head unit when i had one... it's just used to switch on the psu
Mods: Yep
One reason not to buy the Opus orangewhip Power Supplies 31 03-13-2004 05:15 AM
does my opus PS work right? ELEmental59437 Power Supplies 3 01-22-2004 12:04 AM
Hooking Xenarc LCD to opus? XxAndyxX Power Supplies 0 01-20-2004 12:33 PM
What gauge wire for opus? XxAndyxX Power Supplies 6 01-20-2004 12:21 AM
ignition wire for opus psu liquid_smoke Power Supplies 3 09-09-2003 11:58 PM
