Notices
Old 01-25-2004, 09:48 PM   #1
How to test a Sproggy 2.7
I find the search function of this board strange.... it's like if you search for two or more words, like "test +sproggy" you get nothing.... if you search for "test sproggy" you get everything with either word in it... well I digress...
I am trying to test two Sproggy 2.7 PSU that I built for proper voltages, before I plug them into MB's... Don't care to fry any expensive hardware.... One only has the ATX power plug attached, the other only has the Drive Power connectors...
Anyhow, finally I am getting to my questions...
How can you hook up a Sproggy 2.7 to a battery and test the output voltages???? Ofcourse I realize connect the 12VDC+ to the non-coil side of the relay, connect the 12VDC- to the coil of the relay and the 12VDC switched to the other end of the coil of the relay....
Now what do you do with the Power Good and the 5VSB.....
Any suggestions would be most appreciated.... Thanks in advance.
dug1967 is offline   Reply With Quote
Old 01-26-2004, 03:02 AM   #2
Raw Wave
Rob Withey's Avatar
The search form for multiple words would be "search AND sproggy". Can't find the page that says it now, there used to be one. That search turns up loads of pages.
Systems retired due to new car
Rob Withey is offline   Reply With Quote
Old 01-26-2004, 06:03 AM   #3
ok im i dont know what u said about the realy stuff but get a 12V battery to test connect the 12dc+ the the 12Vdc+ on the bat and the 12Vdc- to the - on the bat now put a wire between the green wire ont the atx connector and anyblack wire and it should turn on. then grab your dmm and check that the yello is 12 the red is 5. and the rest are what they are mennt to be. that should do. could be wrong becuase i dont know mutch about the sproggy but that it how i tested my normal pc power supply.
-B-e-N- is offline   Reply With Quote
Sproggy and Compaq Deskpro LDO Power Supplies 28 08-02-2005 09:32 PM
sproggy 2.7 dc PSU output? Help qdrw82 Power Supplies 0 11-05-2003 12:32 PM
sproggy 2.7 power on cheesyhoward Power Supplies 1 06-23-2002 10:44 AM
sproggy 2.7 cheesyhoward Power Supplies 1 02-26-2002 03:53 AM
Sproggy 2.6 or 2.7 PCB's for $5 Mastero Classified Archive 6 01-25-2002 10:01 AM
