Quote: Originally Posted by Crav4Speed
You probably have the wires reversed. Maybe the const+ is on the ign lead and the ign wire is on the const+ lead. Think about it, when the ignition is on, you will have power going through both wires so it will work fine. When you shut the ignition off (which is connected to const+) power is cut off shutting off the power supply
Yah, I figured the same thing. I even swapped them to test the theory when I was trouble shooting; thinking maybe the unit was built with them accidentaly swapped... nope
Thank you though!
