Notices
Old 01-29-2004, 07:00 PM   #1
Need to find acc wire that stays alive during crank.
I'm using a Jeff Mucha shutdown controller and for the "aux" wire I'm going to use the accessory switch wire which goes to my headunit but this wire does not stay alive during cranking. I'm assuming this would cause my system to shutdown when I crank. I don't know where I could find an accessory wire that would stay hot during crank. What is the solution for this?
Upon taking apart the steering column I can see that there are six wires plugged into the ignition barrel thing, but I don't know what any of them are and I don't have a multimeter, I only have a circuit tester so I can only test to see if the wire is hot or not.
Bobby Digital is offline   Reply With Quote
Old 01-29-2004, 07:05 PM   #2
MySQL Error
MatrixPC's Avatar
here you go
http://www.mp3car.com/vbulletin/power-supplies/21179-accessory-line-delay-circuit-any-ideas.html
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is online now   Reply With Quote
Old 01-29-2004, 07:05 PM   #3
Raw Wave
wizardPC's Avatar
www.bulldogsecurity.com
Debt as of 1/1/05: $34,354.48
Debt as of July 4, 2007: $0.00 explanation
Total spent on wedding so far: $3885.79
Thanks to everyone for your support.
I'M DEBT FREE!!
wizardPC is offline   Reply With Quote
Old 01-29-2004, 07:05 PM   #4
Not going to happen...... for tank circuits surving cranks!! Your going to need to build like a tank circuit or buy an OPUS that is the only way to survive a crank!!!
New CarPC on the way again I think. I miss my old one!!!
R3l0ad is offline   Reply With Quote
Old 01-29-2004, 07:09 PM   #5
Umm, I will have a tank in place, but if my accessory wire goes low then it will tell the shutdown controller to send an atx pulse to turn the computer off. Thus my computer will shut down during crank, not due to a loss of voltage but due to the shutdown controller losing +12V on the "aux" line.
Old 01-29-2004, 07:23 PM   #6
robiewp's Avatar
IGN (ignition) found at the ignition harness. On when the car's on, off when the car's off. through cranking and whatnot.
only use this for switching a relay!
Use the source, Luke.
car computer rev 3: 8" lilliput and usual suspects
robiewp is offline   Reply With Quote
Old 01-29-2004, 07:27 PM   #7
How about for switching a shutdown controller, is that acceptable use? And can you specify more where this can be found exactly?
Old 01-29-2004, 07:33 PM   #8
MySQL Error
MatrixPC's Avatar
Read the thread on the link I posted earlier. Combine the ACC and IGN wire together. That will do the trick.
Old 01-29-2004, 08:47 PM   #9
robiewp's Avatar
BALLS! i misspoke. the IGN wire is not on all of the time, only when the engine is.
Matrix, in my car the ACC switches off before the IGN switches on. if you turn the key fast were talking sub 50ms, but there's a state where the key has turned off accessory but not turned on IGN, and depending on how slow you turn the key could be long enough to cause a problem. I know it would trip a simple relay. How do you counter this?
Old 01-30-2004, 05:21 AM   #10
ncamara's Avatar
How about running a wire from the battery?
ncamara is offline   Reply With Quote
Old 01-30-2004, 10:45 AM   #11
MySQL Error
MatrixPC's Avatar
You mean the ACC wire is cut off when switch from ACC to IGN?
That is odd. Well that could be for some American cars/Eupopean cars that I don't know of.
Old 01-30-2004, 01:17 PM   #12
Just delay the shutdown controller for a few seconds before it sends the ATX power pulse (R1 on the MPEGBOX SDC). If the IGN line goes low while cranking but turns back on after cranking the shutdown controller won't send the pulse to shutdown the computer.
audrenaline is offline   Reply With Quote
Old 01-30-2004, 01:27 PM   #13
Raw Wave
I thought the ACC turn off then you crank the engine...it does stay on when the key is on the IGN, the normal position when driving the car.
This is what I know :
ALL OFF > ACC ON > ACC ON and IGN ON > ACC OFF, IGN ON and STARTER ON.
You need to have your IGN on while cranking and during driving, engine wont start without Ignition, hence the name IGN
ACC can go off during cranking as this is only for radios and such...not required to start your engine.
But of course some cars are different, but it should be fairly standard
Ricky327 is offline   Reply With Quote
Old 01-30-2004, 03:16 PM   #14
NJay's Avatar
I think what robiewp is saying is that if he turns the key to midway between the ACC and IGN points neither are active on his car and hence joined dioded arrangement won't work MatrixPC suggested won't work as that relies on at least one being active.
My CarPC install piccies http://www.celica-club.co.uk/cgi-bin...at=561&thumb=1
NJay is offline   Reply With Quote
Old 01-30-2004, 06:28 PM   #15
Good thought, but I have modified the shutdown controller to also send an atx pulse when the aux line goes high (thus it is now a startup and shutdown controller). See this thread for how.
So, even if I delay the shutdown atx pulse, a startup atx pulse will be sent once I stop cranking and the accessory line goes high again.
In search of an ignition wire witten Power Supplies 16 07-27-2006 02:29 AM
ignition wire for opus psu liquid_smoke Power Supplies 3 09-09-2003 11:58 PM
